92 B18a1 in to a 93 VX
Will the VX wirning harness hook up to the b18a1 without modifacations. Will the mounts off the VX work with the engine. Also do I need the a1 ecu or can the LS ecu be used?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM »</TD></TR><TR><TD CLASS="quote">Will the VX wirning harness hook up to the b18a1 without modifacations.</TD></TR></TABLE>
Not without modifications, but it would only take extending a few wires and converting to a 4 wire O2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM »</TD></TR><TR><TD CLASS="quote">Will the mounts off the VX work with the engine.</TD></TR></TABLE>
No. You will need:
Driver's side mount bracket and mount - 94-01 Integra
Rear engine bracket - 94-01 Integra
Upper tranny mount bracket and mount - Stock
Front lower tranny mount - 94-01 Integra
A/C mount bracket - 95 Del Sol VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM »</TD></TR><TR><TD CLASS="quote">Also do I need the a1 ecu or can the LS ecu be used?</TD></TR></TABLE>
You should use a 92-93 PR4 Integra ECU or 94-95 P74 Integra ECU.
No. You will need:
its a 92 b18a going into a 93 VX whats with the 94 - 01 integra stuff? I thought all you needed was.
Mounts that came with the motor.
Shift linkage
ECU
Axles
Damn this gets more complicated every day my head hurts...
Shift linkage
ECU
Axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVM »</TD></TR><TR><TD CLASS="quote">its a 92 b18a going into a 93 VX whats with the 94 - 01 integra stuff?</TD></TR></TABLE>
Yeah it's a 92 B18A but that's also from a different chassis than the EG Civic and DC Integra. The mounts and brackets from the 92 B18A will not work so they need changed with 94+ Integra parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
Stock as in stock VX or stock as in the motor im swaping in.
alexsracing
Jan 2, 2005 08:22 PM
blueintegra90
Jun 11, 2004 04:03 PM
