What B-series manifold to use a Greddy TD40H-15G turbo?
Old Apr 26, 2003 | 12:06 PM
bumpin_bass's Avatar
Default What B-series manifold to use a Greddy TD40H-15G turbo?
What B-series manifold do I need to buy so I can use the d-series 1.6L greddy kit with the TD40H-15G turbo on my B16a engine? Let me know brands and bolt patterns and cost? Thanks
Old Apr 26, 2003 | 12:12 PM
specie's Avatar
Default Re: What B-series manifold to use a Greddy TD40H-15G turbo? (bumpin_bass)
You can get the Greddy B-series manifold.
Or you can find a b-series exhaust manifold gasket (use as an outline) and slot/port the d-series manifold to work on the B-series head.
Old Apr 26, 2003 | 04:47 PM
ttt
Old Apr 26, 2003 | 10:57 PM
JalopySiR's Avatar
HKS B16 manifold. NOPI.COM... Flanges are the same. Standard Garrett T25. GL
Old Apr 26, 2003 | 11:45 PM
boostinb18's Avatar
Default Re: What B-series manifold to use a Greddy TD40H-15G turbo? (JalopySiR)
you dont need a new manifold... just slot the bolt holes on the d-series manifold and take out the outside studs and it will bolt up, thats what i did. works great!
Old Apr 26, 2003 | 11:49 PM
Default Re: What B-series manifold to use a Greddy TD40H-15G turbo? (boostinb18)
OK thanks, I don't wanna spend more money. Do I just slot the holes so they match the bolt pattern, or is there another reason for this? What tool do I use to take out the outside studs and slot the holes with?
Old Apr 30, 2003 | 02:37 PM
schmidty's Avatar
For those of you w/ experience with the 15g/b16 combo, how did this perform for you? I imagine super quick spool, but did top end die off big time... was the turbo even big enough to flow suffiecient air w/ out cranking up the boost big time?
Old Apr 30, 2003 | 06:16 PM
Charles B.'s Avatar
Default Re: What B-series manifold to use a Greddy TD40H-15G turbo? (schmidty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schmidty &raquo;</TD></TR><TR><TD CLASS="quote">For those of you w/ experience with the 15g/b16 combo, how did this perform for you? I imagine super quick spool, but did top end die off big time... was the turbo even big enough to flow suffiecient air w/ out cranking up the boost big time?</TD></TR></TABLE>
if your going to throw the 15g on a b-series, i would throw it on an LS. the redline is less than a b16 so the turbo won't choke as much. hth.
Old Jun 29, 2009 | 12:45 PM
b-ready's Avatar
I am doing the same thing with my b16. You can also use the Edelbrock b series manifold. Thats what I did. You can pic one up for $180-$200ish.
Old Jun 29, 2009 | 01:02 PM
HiProfile's Avatar
Hey great 2nd post. Any other ancient, useless threads you want to dig up??
ALWAYS be careful of the date, especially if you're new and thinking of offering advice.
CALM_AS_A_BOMB
Apr 7, 2005 08:50 PM
brixity
Mar 5, 2005 02:53 PM
adotlee
Mar 10, 2004 05:48 AM
bumpin_bass
Apr 28, 2003 11:00 PM
nsxmatt
Jan 18, 2003 08:06 PM
