A few pics for ya guys to check out....(turbo, manifold, vaccum manifold) no 56k...
Old Apr 26, 2003 | 10:04 AM
GraphiteAccord's Avatar
Default A few pics for ya guys to check out....(turbo, manifold, vaccum manifold) no 56k...
Hey guys, i got my manifold from Tinker219. He was great to work with, and this is the first h22a manifold he's ever built...especially one for my project which will be finished soon: A 1990 Honda Accord with a JDM h22a....lets cut straight to the pics now...
First, my mcmaster-carr Vaccum manifold:
Front view:
Next: Turbo
Balancing Act
nissan!
And now, last but not least, the tink219 manifold...
Thanks for checking out my pics guys, have any questions, feel free to ask...
Old Apr 26, 2003 | 10:34 AM
Default Re: A few pics for ya guys to check out....(turbo, manifold, vaccum manifold) no 56k... (GraphiteAcc
nope, custom turbine housing off an old school volvo. a friend of a friend built the turbo for me with space constraints in mind, and thought that that internal wastegate would be best......
what you don't see is my 10 mandrel bends of various 2.5" and 2" piping, my oil return, and my Flamenco-T feed line. just waiting for a coupler from atpturbo to get here, and i'm done!
Old Apr 26, 2003 | 10:39 AM
WA  DA  TA's Avatar
What volvo is that from? I looks like it is from a diesel, but not for a volvo. Volvo would be .36 stock. BTW, these turbine housings kick serious ***... no creep, very efficient, 4 bolt design, and fully adjustable WG...
PhxK20a3's Avatar
Looks good Joe! When do you plan on having it all on the road?Believe me,boost OWNS all motor...
Old Apr 26, 2003 | 10:42 AM
Flamenco-T's Avatar
nice pics Joe...
stan
Old Apr 26, 2003 | 10:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhxK20a3 &raquo;</TD></TR><TR><TD CLASS="quote">Looks good Joe! When do you plan on having it all on the road?Believe me,boost OWNS all motor... </TD></TR></TABLE>
should be done as soon as i get a 2" to 2.5" coupler from atpturbo, its in the mail i hope....so somewhere like a week or so...
Old Apr 26, 2003 | 10:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">nice pics Joe...
stan
thanks stan,
when should i send my block to ya to send to GE? let me know
Old Apr 26, 2003 | 10:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsx4R1 &raquo;</TD></TR><TR><TD CLASS="quote">What volvo is that from? I looks like it is from a diesel, but not for a volvo. Volvo would be .36 stock. BTW, these turbine housings kick serious ***... no creep, very efficient, 4 bolt design, and fully adjustable WG... </TD></TR></TABLE>
No idea on the size, its marked 48, but i was told it was .60 turbine with a .63 compressor with a super 60 wheel....He bragged about this wastegate a lot...and i love the bolt down pipe with the studs from the factory....
Old Apr 26, 2003 | 10:57 AM
project dc2's Avatar
info on vac manifold ?
Old Apr 26, 2003 | 11:04 AM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">info on vac manifold ? </TD></TR></TABLE>
Great pics.
Old Apr 26, 2003 | 11:18 AM
inspyral's Avatar
http://www.mcmaster.com catalogue pg 159
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Metal and Thermoplastic Manifolds
Build your ideal flow system, starting with these manifolds. Just thread in the fittings you want to use for customized multiple connections to one source. Use plugs (sold separately) to close off outlets not in use. Manifolds have two inlets, one at each end, and two mounting holes. Connections are NPT female (except where noted). BSPP— British Standard Pipe Parallel Thread. BSPT— British Standard Pipe Tapered Thread.
Aluminum— Aluminum alloy 6061 offers high corrosion resistance and protection from contaminants. Withstands working pressures to 3000 psi hydraulic, 1000 psi air. NPT models have a black anodized finish; BSPP and BSPT models have a plain aluminum finish. Temperature range is —10° to +200° F.
Mine is coming next week
Old Apr 26, 2003 | 03:29 PM
WA  DA  TA's Avatar
Its a .48 likely stage 1 wheel. They do not make anything larger than .48 a/r and stage 1 in that style of turbine housing and it is for diesels. Not that it will not work on a gas engine...
Should work very well however
Old Apr 26, 2003 | 07:01 PM
4gen's Avatar
I have some more pics coming your guys' way just as soon as i get a chance to upload them, got busy with dinner/plans tonight, but will definately get a chance in the morning, everything fits good, had to actually flip the turbo so that the exh turbine is on the motor mount side and the comp housing is on the alternator side, and had some hood clearance issues, but its all good now, thanx to a handy rotary saw and taking out some of the hood reinforcement. After putting a dent in the hood from the comp housing, we got everything fitted good and it looks like an awesome setup. All that Joe has to do now is get that part (2-2.5in), and get the dp and intercooler piping setup. This car is great NA already but Joe's gonna be a happy camper once we get this car boosted. peace, Andy B.
Old Apr 26, 2003 | 07:35 PM
Henry HA's Avatar
HAnda-Tech Member
newb question:
WTF is that?
Old Apr 27, 2003 | 08:53 AM
haha, i got it for 23 dollars shipped, with all the fittings and plugs i need from mcmaster-carr. I had a good deal lined up on the golden eagle one, but i couldn't justify the cost of 20$ more and still not have any fittings and holes drilled in it...
BTW, the accord front motor mount is coming out. time for a prelude front motor mount setup.
Old Apr 27, 2003 | 11:29 AM
Mr. Softee's Avatar
pimp dude. maybe you will get this done afterall (thisis azteg on csi)
Old Apr 27, 2003 | 12:06 PM
RR98DX's Avatar
nice joe! i can't wait to see this thing run man.
Old Apr 27, 2003 | 12:26 PM
egg's Avatar
egg
damn thats a great find. the vaccum manifold cost under $17 for 6 outlets with a 3/8" inlet and 1/4" outlets. who the hell would wanna pay $50 for a golden eagle manifold!?
Old May 4, 2003 | 08:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg &raquo;</TD></TR><TR><TD CLASS="quote">damn thats a great find. the vaccum manifold cost under $17 for 6 outlets with a 3/8" inlet and 1/4" outlets. who the hell would wanna pay $50 for a golden eagle manifold!?</TD></TR></TABLE>
my thoughts exactly...
Old May 4, 2003 | 08:22 PM
88ZCRX's Avatar
McMaster is the ****. I got my turbo feed line and tee from there for less than I could have anywhere else. They have everything you could need and even more stuff you couldn't possibly ever need (but might want because it would be cool).
Old May 4, 2003 | 09:33 PM
sickness's Avatar
Let me know if you need help
Old May 4, 2003 | 11:27 PM
Midwestrider's Avatar
Hey man..
Did you get the Aluminum one w/ 3/8 inlet and 1/4 outlets?
Did the feed plugs come w/ it?
Thanks
Old May 5, 2003 | 07:22 AM
teamlegacy's Avatar
That thing is gonna haul ***!
BMCRace
Welding / Fabrication
25
Dec 2, 2009 02:33 PM
Full-Race Geoff
May 22, 2004 06:24 AM
B16A1-EF9
Sep 24, 2003 06:06 AM
boosted jetta
Jul 9, 2003 06:28 PM
