I HATE rear drums. Disks for EK Sedan?
Old Apr 25, 2003 | 09:03 PM
Chris's Avatar
Default I HATE rear drums. Disks for EK Sedan?
What will I need.. and from what car?
Remember.. this is a 98 4 door EX.
Could I use the 99+ Si rear suspension? Drums suck sooo bad as far as replacing pads. It would be worth it for me to just swap disks in there.
Thanks for your time.
Old Apr 25, 2003 | 09:39 PM
eg686's Avatar
Default Re: I HATE rear drums. Disks for EK Sedan? (Chris)
im not sure but dotn sedans already have rear disc brakes?
Old Apr 25, 2003 | 09:40 PM
GhettoBrawls's Avatar
you can use the 99 + si rear brakes or any of the integra rear brakes.
Lord Helmet's Avatar
depends if you want to do it the cheap route or expensive route.
cheap route: go to local junkyard and get a 94-up integra ls or gsr rear suspension (or find civic w/abs and use that but ditch the abs wiring), about $250 for whole rear suspension. it is a direct bolt on affair ever thing is used so inspect everything.
expensive route: buy the aem drum to disc brake conversion kit, about $400-500. also a direct bolt on with no problems. everthing is brand new.
it's your choice
Old Apr 25, 2003 | 09:41 PM
IM ALL BOB's Avatar
I went with 99 si rear disc in back with the whole trailing arm as well from the 99 si... (I have a 98 hatch) went right up no problems basically .. it's a bitch to do if u don't have a lift... but this type of mod helps alot with nose dive.. but I believe you should do a upgrade of the Master cylinder with larger front brakes.. because that will honestly improve your braking more seriously ... you can also use any integra rear disc as well but you'll be using your stock civic trailing arm good luck
Old Apr 25, 2003 | 09:44 PM
Default Re: I HATE rear drums. Disks for EK Sedan? (IM ALL BOB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">I went with 99 si rear disc in back with the who trailing arm as well fro the 99 si... went right up.. it's a bitch to do if u don't have a lift... but helps alot with nose dive.. but I believe you should do a upgrade of the Master cylinder with larger front brakes.. because that will honestly improve your braking more seriously </TD></TR></TABLE>
I never needed a lift to do the rear disc conversion. but you did?
but yeah it would be a good investment to buy the master cylinder and brake booster to offset the balance of the rear brakes. I haven't done that yet but is in my future mod list.
Old Apr 25, 2003 | 09:45 PM
IM ALL BOB's Avatar
Default Re: I HATE rear drums. Disks for EK Sedan? (sleeperciv)
nah just makes it easier.. since the whole trailing arm and drum brakes weigh a ton if you are by yourself ... but no u don't need it..sorry MR.HULK
Old Apr 25, 2003 | 09:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IM ALL BOB &raquo;</TD></TR><TR><TD CLASS="quote">nah just makes it easier.. since the whole trailing arm and drum brakes weigh a ton if you are by yourself ... but no u don't need it..sorry MR.HULK </TD></TR></TABLE>
I just put a floor jack under the rear suspension and just jack it up and align everything. just my way and probably everybody's too....I hope.
Old Apr 25, 2003 | 09:50 PM
IM ALL BOB's Avatar
I don't know, I guess your mad at me for using a lift
Old Apr 25, 2003 | 09:56 PM
I wish I had a lift though.
for bob having access to a lift.
Old Apr 25, 2003 | 11:53 PM
@irborne's Avatar
i have the rear disc setup from a 98 integra PM me if you're interested.
SkyliteCustomz
Jun 28, 2007 03:59 PM
B16B_coupe
Oct 1, 2006 07:05 AM
808k20hatch
Sep 18, 2006 01:40 AM
griggc
Mar 28, 2006 12:50 AM
RedEj8
May 30, 2005 08:25 PM
