popping sound from speakers and sub!
Old Apr 25, 2003 | 05:30 PM
agent marlon's Avatar
Default popping sound from speakers and sub!
everytime i change the volume settings to 0-1..back and forth i get a loud popping sound and also when i change around the sound settings, change tracks on a cd, change to tuner then back to cd...it pops and it lasts for like a second....what's the deal?
Old Apr 25, 2003 | 05:54 PM
vteg's Avatar
New User
Default Re: popping sound from speakers and sub! (agent marlon)
What do you have?
Old Apr 26, 2003 | 08:16 AM
Default Re: popping sound from speakers and sub! (vteg)
anyone?
Old Apr 26, 2003 | 08:24 AM
nsxxtreme's Avatar
You might answer his question first.
Old Apr 26, 2003 | 09:28 AM
Hondaaccordvtec's Avatar
Default Re: popping sound from speakers and sub! (nsxxtreme)
We can help you, but you need to give a little more info. such as are the speakers running off your deck or an amp(s)? How are the amps wired? How do you have your wires run? Power/ground down one side of the car and the RCA's on other? How old is the equipment? What kind of deck? What kind of electronics? What kind of speakers? How are the speakers hooke up. Do you hear the POP noise through the front/rear/and sub?
Once you give this info and other - then the people of this board might be able to diagnoise what could be wrong.
Old Apr 27, 2003 | 07:43 AM
Default Re: popping sound from speakers and sub! (Hondaaccordvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">We can help you, but you need to give a little more info. such as are the speakers running off your deck or an amp(s)? How are the amps wired? How do you have your wires run? Power/ground down one side of the car and the RCA's on other? How old is the equipment? What kind of deck? What kind of electronics? What kind of speakers? How are the speakers hooke up. Do you hear the POP noise through the front/rear/and sub?
ok..here's the deal...i got the front speakers wired to the front channel of the amp...and i got the sub bridged on the rear channel of the amp...my power cable is ran on the left side of my car...and my rca's are ran on the right side of my car and my speaker cables are ran under my my center console...the ground for the amp is under the back seat....my equipment is that old at all..eclipse 36401 amp and a pioneer deh7400mp hu, and pioneer 120 watt speakers all around...and with everything hooked up..i haer the popping through the front and sub...cause that's all i have hooked up...
Old Apr 27, 2003 | 04:32 PM
What is your gain setting on the eclipse amp? Do have it turned up all the way? If so, try backing it down.
DO have another amp you can try? (just to make sure it is not the amp making the noise)
Try disconnecting the sub rca's from the amp and see if the pop noise still present.
Try " " speaker rca's " " " " " " " " "
Are you using the same kind of gauge wire for your power and ground?
Old Apr 28, 2003 | 09:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">What is your gain setting on the eclipse amp? Do have it turned up all the way? If so, try backing it down.
Are you using the same kind of gauge wire for your power and ground?</TD></TR></TABLE>
i tried the adjusting the gain really low on my amp..and i could still hear a faint pop..i've disconnected the sub rca..but still pop from speakers..disconnected the speaker rca and reconnected sub rca..and still pop from sub...i ve used different rca's and different amps...and still pops..i've put my HU in my brothers car..and it pops in his car...tried HIS hu in my car and it sounds ok...but could it be a bad wire harness?..
Old Apr 28, 2003 | 01:21 PM
Try not using the wire harness. Make a wire right to battery (for both inigition and power and an additional wire for ground - make sure to attach it to bare metal, sand down the paint if necessary). see if you still get the popping noise. also make sure your amp ground wire is in contact with bare metal.
Old Apr 28, 2003 | 04:45 PM
markben151's Avatar
i had that problem a while ago and i just replaced my rcas and it worked out fine
Old Apr 29, 2003 | 09:55 PM
romeo619romeo's Avatar
Default Re: popping sound from speakers and sub! (markben151)
either bad RCA or bad ground ...
type Gendy
Audio / Security / Video
Nov 26, 2005 10:09 AM
anteater
Mar 24, 2005 10:31 PM
JDM_Type-R
17
Aug 18, 2004 07:02 PM
miksew
May 1, 2004 07:40 AM
Linh.
30
Mar 9, 2004 05:57 PM
