How much does it cost to build B18B bottom end?
Old Jun 30, 2001 | 09:51 PM
E Swift's Avatar
Default How much does it cost to build B18B bottom end?
I decided I'm keeping my B18B motor. I want to go turbo next summer, so, this year, I'm building the bottom end. I want to Hone out the cylinders, replace the pistons, rods, and rings. And, also, I want to do a port and polish while i'm doing this all. How much will all of this cost me about? What's the cost of each procedure? I plan on going with low compression pistons, such as possibly JE pistons. So, if anyone can help, give me a breakdown of the cost of each.
Thanks
Old Jul 1, 2001 | 01:21 AM
ILOVEGIRLS's Avatar
Default Re: How much does it cost to build B18B bottom end? (420TegLS)
je pistons..500
crower rods..600
resleeving..800
i forgot how much all the bearings and the gasket costs..hope this helps
Old Jul 1, 2001 | 01:22 AM
Vtec integra's Avatar
dont you wanna resleeve the block?
well here's what it cost me
pistons 450-500 w rings
hone-175
rods-350-550
port polish 150 (its a basic port just the exhaust side)
3 angle 175
balance motor-150
putting together motor is around 600
well these are just the prices that i have gotten
Old Jul 1, 2001 | 10:33 AM
E Swift's Avatar
Default Re: How much does it cost to build B18B bottom end? (Vtec integra)
What's the 3 angle do? I've heard other people talk about it before, but, never understood what it actually does.
Old Jul 1, 2001 | 10:37 AM
LSIntegra94's Avatar
New User
It promotes a smoother air flow.
Old Jul 1, 2001 | 10:39 AM
E Swift's Avatar
Default Re: How much does it cost to build B18B bottom end? (LSIntegra94)
What about sleeving it? What is this process all about?
Old Jul 1, 2001 | 01:04 PM
well you want to go turbo it would be best to sleeve your block
your stock sleeving can only take so much pressure before blowing up
with the new sleeving you can also boost highier too
sleeving i can get for about 900
its the same sleeves ed berganholtz uses
after you get those sleeves you can aalso think about spraying for all that turbo lagg
Old Jul 1, 2001 | 09:57 PM
E Swift's Avatar
So, exactly how much will I be spending about to rebuild my entire motor, so that it'll be able to withstand about 12lbs. of boost?
Old Jul 1, 2001 | 10:46 PM
OneThirtyEight's Avatar
um yes, hell im not doing jack to my LS engine and putting around 8psi on it. Well see what happens.
chriscool888
May 9, 2012 07:24 AM
Xion
May 31, 2003 05:06 PM
ITRfaithful
Feb 14, 2003 08:51 AM
1hotintegra
Jul 16, 2002 05:03 PM
