SMC driving me crazy,i need help,somebody help me please
Old Apr 25, 2003 | 04:56 PM
civicguy's Avatar
Default SMC driving me crazy,i need help,somebody help me please
im using the smc on obdo pm6 ecu and im getting a code 13(atmospheric pressure) now when i go for a ride i get code 3(map sensor)code 7(throttle angle) and the code 13(atmospheric pressure) the car idles like stock,i had reset the ecu like 25 times,but nothing.even before i start up the car is aready throwing the codes
Old Apr 25, 2003 | 04:57 PM
turbod16y8's Avatar
Default Re: SMC driving me crazy,i need help,somebody help me please (civicguy)
list your setup and settings.
Old Apr 25, 2003 | 05:05 PM
civicguy's Avatar
Default Re: SMC driving me crazy,i need help,somebody help me please (turbod16y8)
91 civic si d16z6 turbo,pm6 ecu,rc440 injectors
fuel pressure is at 40 psi,spark plugs gap at 30,the car feels fine but im scared about this codes i just finished putting the turbo yesterday,theres no bogging or anything
my settings
idle-48
1000-40
2000-39
3000-38
4000-37
5000-36
6000-36
7000-36
8000-36
this is on the smc500
Old Apr 25, 2003 | 05:11 PM
turbosol's Avatar
If it throws codes before you start the engine, it sounds like you have something unplugged or swapped. I've read that MAP and TPS plugs are the same and can be swapped, maybe thats your problem.
Old Apr 25, 2003 | 05:23 PM
civicguy's Avatar
Default Re: SMC driving me crazy,i need help,somebody help me please (turbosol)
i emailed zip yesterday and he told me that usually map sensors wire are red/green or white/yellow so i did look at the pinouts that came inthe instructions and did not found the green/red wire but did found the white/yellow so ihooked from there,but now thinking thats my be the problem because it always happen when i flored i may haved on the tps and not on the map
Old Apr 25, 2003 | 07:22 PM
Slammd Sol's Avatar
how much boost are you running with those settings?
Old Apr 25, 2003 | 07:37 PM
civicguy's Avatar
Default Re: SMC driving me crazy,i need help,somebody help me please (Slammd Sol)
have not been taken above 4 psi
Old Apr 25, 2003 | 07:54 PM
Slammd Sol's Avatar
I am running 7psi right now.. my settings are:
Idle: 34
1-2: 38
2-3: 37
3-4: 36
4-5: 36
5-6: 35
6-7: 34
7-8: 33
I was getting a Map sensor CEL until I leaned out my fuel a bit. I was running Extremely rich. Everything seems to be fine now. As for your CEL's.. I would check all the SMC wires and make sure your map line in and out are connected right. And make sure you didnt ground the green wire off the SMC..
Old Apr 26, 2003 | 07:50 AM
civicguy's Avatar
Default Re: (Slammd Sol)
ttt
Old May 7, 2003 | 10:51 PM
zip's Avatar
zip
Pablo, we have received your SMC500. The reason you were throwing codes is because:
1) You reprogrammed the clamping voltage higher than 3.00 - 3.10V causing the ECU to sense boost. You must have neglected to follow the programming procedures in the manual and accidently reprogrammed the voltage clamp.
2) You programmed different rpms non linearly. We found the following settings:
Idle, 1K, 2K, 3K, 4K, 5K, 6K, 7K, 8K = -59%
1.5K, 2.5K, 3.5K, 4.5K, 5.5K, 6.5K, 7.5K, 8.5K = -35% (factory settings)
You seem to have not followed the directions concisely causing erratic operation. The reason it was flooding was that the MAP sensor voltages changed from -59% to -35% every 500rpm. The ECU threw a TPS code was due to the gas pedal being in relatively the same position, but with a rapidly fluctuating MAP signal every 500rpm.
Old May 9, 2003 | 01:58 AM
GOLDBERG's Avatar
Default Re: SMC driving me crazy,i need help,somebody help me please (zip)
efnborder
Aug 14, 2010 10:19 PM
itslogz
Jul 19, 2010 07:17 PM
Ricta
Jan 16, 2006 06:45 PM
luciffer
Oct 4, 2005 05:44 AM
TurboDC4
Mar 20, 2003 10:41 AM
