99-00 civic green plug ecu pinouts
Old Apr 25, 2003 | 10:00 AM
HybridHatchC1's Avatar
Default 99-00 civic green plug ecu pinouts
exactly what the title says i am looking for 99-00 civic green plug ecu pinouts, i am useing the 96-98dx harness for my swap but i need to add this plug.
so right now i have a 98 gsr swap going into a 2000civic ex and i have 3 harnesses 1 96-98 dx(using for the swap) 1 99-00 civic ex, and 1 98 gsr harness am i useing the right harness to begin with, i was told to use this one, i just need the pinouts for the green plug from a 99-00 civic ex, thanks
Old Apr 25, 2003 | 11:06 AM
Trey's Avatar
25 Year Member
Default Re: 99-00 civic green plug ecu pinouts (HybridHatchC1)
Just get a 99 GSR ecu and use the 99-00 EX harness. Add one wire for the IAB and you are all set.
Old Apr 25, 2003 | 11:13 AM
Scott - 93HB Si's Avatar
Default Re: 99-00 civic green plug ecu pinouts (Trey)
96-99 GSR are all the same ECU, they changed to the different plug style in 00-01...but they also have the imobilizer in them i believe.
Old Apr 25, 2003 | 04:00 PM
voltronmas13's Avatar
Default Re: 99-00 civic green plug ecu pinouts (Scott - 93HB Si)
i just did this same swap a week ago use the ex harness and get a kenji conversion harness to use the 96-98 gsr ecu if want to stay obd2
EFityo
Dec 26, 2012 04:26 AM
RyanA
Jan 20, 2007 08:08 AM
shadykit
Aug 7, 2004 04:36 PM
shadykit
Aug 1, 2004 08:28 PM
dry-ice
Mar 13, 2003 06:07 PM
