3" DP people.. post pics of where your flange meets the pipe...
Old Apr 25, 2003 | 08:35 AM
BoostedH23a1's Avatar
Default 3" DP people.. post pics of where your flange meets the pipe...
well im not sure if i will have room to put in the bolts... how would i do that..post up pics
Old Apr 25, 2003 | 08:40 AM
TurbodCX's Avatar
Default Re: 3" DP people.. post pics of where your flange meets the pipe... (BoostedH23a1)
Do you mean the flange where the DP meets the turbo?? if so i had to use a 2.5" donut for the first 2 inches then i hook the 3" to that.
close enough to a full 3in for me.
I noticed a good power gain out of doing this also, since my original DP was only 2.25" (dont ask why)
Brian
Old Apr 25, 2003 | 08:42 AM
Default Re: 3" DP people.. post pics of where your flange meets the pipe... (TurbodCX)
yea where flange meets the turbo.. btw i have a 5 bolt turbonetics t3/t4b
Old Apr 25, 2003 | 08:57 AM
XES's Avatar
XES
Here is how I got around the problem of using a 3" DP without enough room (just have the bolt in place before the weld is made!).
GraphiteAccord's Avatar
http://www.atpturbo.com...go to the turbo catalog and browse alittle bit. He has these 2.5" rings flared to 3", what they do is, you weld the 2.5" to the flange, and then it immediatly flares, and weld the 3" pipe to it....what sucks is, i already planned to go with a 2.5" down pipe till i saw this, now i'm considering a 3", but i already have everything to build a 2.5"....
Old Apr 25, 2003 | 09:41 AM
true's Avatar
Full 3" on the 4 bolt flange works if you're careful and use round head bolts like I did:
Also as people have mentioned just flare it to 3 from the flange and it will be fine.
Old Apr 25, 2003 | 10:07 AM
93LSivic's Avatar
Default Re: 3" DP people.. post pics of where your flange meets the pipe... (true)
Damn, Im gonna have fun making my downpipe. The outlet of the turbine is larger then my 4 bolt flange that I have. Oh well, out comes the die-grinder
Old Apr 25, 2003 | 10:34 AM
Default Re: 3" DP people.. post pics of where your flange meets the pipe... (93LSivic)
damnit i have 5 bolt flange
Old Apr 25, 2003 | 11:13 PM
Old Apr 25, 2003 | 11:23 PM
inspyral's Avatar
V-band adapter:
Old Apr 26, 2003 | 12:00 AM
Default Re: 3" DP people.. post pics of where your flange meets the pipe... (inspyral)
yea i just ordered that adapter for 2.5 to 3... and a flex pipe
wade
Welding / Fabrication
Dec 29, 2010 06:42 PM
Legion
Feb 22, 2008 05:30 PM
BlueShadow
Jul 31, 2005 09:10 PM
theo99gsr
Jul 3, 2005 11:17 AM
94TurboGSR
Sep 21, 2003 10:51 PM
