Oil Change Question.
Old Apr 25, 2003 | 06:38 AM
RaVAGE00's Avatar
New User
Default Oil Change Question.
I was just surfing the c-speed site... looked over the oil change procedure....
"Now you can go ahead the fill the motor with the new oil. Do not over fill it. B18C1 and B18C5 require 4.25 quarts. B18B - 4 quarts. Put the filler cap back on, lower the car and start it up. Let the engine run for a few minutes to circulate the new oil. Do not rev the motor during this time"
Do not rev the motor during this time??? I have seen a few oil changes done at these quick jiffy lube places.... the first thing they do is start the engine and rev it for a couple of seconds, before checking the oil level....
Old Apr 25, 2003 | 06:44 AM
Nameless RB26's Avatar
Default Re: Oil Change Question. (RaVAGE00)
I've seen people fill the oil while the engine is running.. and they check the fill level too.
Old Apr 25, 2003 | 06:47 AM
RaVAGE00's Avatar
New User
Default Re: Oil Change Question. (Nameless EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">I've seen people fill the oil while the engine is running.. and they check the fill level too. </TD></TR></TABLE>
COME ON!!!!!
Old Apr 25, 2003 | 07:28 AM
IN VTEC's Avatar
I had a friend that did that with his GS-R. It spat it back at him.
You don't need to rev the engine. It takes even longer to build up oil pressure after you change the oil compared to a cold start. If you rev it immediately after starting it you're liable to cause some chafing and start a fire. Well...maybe not the fire part.
Old Apr 25, 2003 | 07:40 AM
RaVAGE00's Avatar
New User
Default Re: Oil Change Question. (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
You don't need to rev the engine. It takes even longer to build up oil pressure after you change the oil compared to a cold start. If you rev it immediately after starting it you're liable to cause some chafing and start a fire. Well...maybe not the fire part.</TD></TR></TABLE>
Cool... next time I am at Mr. Lube I am going to tell them NOT to rev the engine after the oil change.
Old Apr 25, 2003 | 09:05 AM
oryanh's Avatar
Better yet... do the oil change yourself.
Those "lube" places generally don't care about your car as you do.
The "revving" is their baseless attempt to speed up the process because they are impatient, and unwilling to fill the filter with oil before putting it on.
Laziness should not be a factor in maintaining your car.
Old Apr 25, 2003 | 10:01 AM
trustbuddy's Avatar
Default Re: Oil Change Question. (oryanh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oryanh &raquo;</TD></TR><TR><TD CLASS="quote">Better yet... do the oil change yourself.
exactly.
Old Apr 25, 2003 | 10:09 AM
RaVAGE00's Avatar
New User
You assumed that I dont.... and you know what they say when you assume....
I said next time I am at Mr.Lube.... I did not say anthing about the next time I am at Mr. Lube with my R.... I do all my own oil changes.
Thanks.
Old Apr 25, 2003 | 11:01 AM
oryanh's Avatar
Don't take it as an insult. I'm only speaking general terms here.
So do you plan on taking a car to Mr. Lube or not?
lesson learned:
I'll <U>not</U> assume that when you say, "Next time I'm at Mr. Lube".
...that you actually plan on going to Mr Lube.
globy123
12
Oct 18, 2009 03:01 PM
h2392si
16
Aug 25, 2005 07:18 AM
blackjdmEKcivic
Nov 14, 2004 09:38 PM
Vouthanack
Jul 30, 2004 11:18 AM
itr501
Sep 10, 2001 10:28 PM
