spring install tomorrow (need some help)
Old Apr 24, 2003 | 08:42 PM
yellowbuffalo's Avatar
Default spring install tomorrow (need some help)
Im installing some H&R springs on my friend car tomorrow. We have everything we need but do we need a torque wrench ??? The last time i did a spring install was in NC so im a little confused on how the springs differ efrom each other which two are the fronts which two are the backs?? And are the tops where its narrower? I know i may sound crazy but I need this.
Old Apr 24, 2003 | 08:44 PM
neo1z's Avatar
Default Re: spring install tomorrow (yellowbuffalo)
1) You do not NEED a torque wrench.
2) H&R's have F and R on them, you can guess which go where.
3) Regarding the narrower thing, when you put them on the shock, youll be able to tell which go where.
Best of luck.
Old Apr 24, 2003 | 09:07 PM
basmasta7's Avatar
Default Re: spring install tomorrow (neo1z)
watch out for breaking the heads off the lower shock bolts. it sucks *** - i ended up breaking both mine off.
Old Apr 24, 2003 | 09:27 PM
justininhifi's Avatar
Default Re: spring install tomorrow (basmasta7)
Im also installing a new suspension tomorrow. Kyb agx with ground control coilovers. Can anyone give me any heads up? I read somewhere that someone needed to file a 1/4" mark on the agx's so the GC perch can rest on it. Any help would be awesome, Thanks guys. Justin
Old Apr 24, 2003 | 10:08 PM
tC_Dragon's Avatar
Default Re: spring install tomorrow (justininhifi)
go check out the articles on team-integra.net ... its decent readin to prep u for wat u will be doing.
Old Apr 25, 2003 | 09:12 PM
stumpyf4's Avatar
Default Re: spring install tomorrow (pdcdragon)
diameter of the wire will be larger in the front than in the back
Old Apr 26, 2003 | 04:00 AM
HondaIntegraLS's Avatar
Actually you DO need a torque wrench. If you are putting your wheels back on and dont want warped rotors, you will need to torque them on.
Old Apr 26, 2003 | 10:06 AM
JoshRambo's Avatar
refer to this site if you get stuck. it is rather easy.
http://www.itrca.com/FAQ/diy/suspension.php
Old Apr 26, 2003 | 02:39 PM
acatak's Avatar
Default Re: spring install tomorrow (Gravity)
I would def soak the rear LCA bolts with PB Blaster before you try to take them off.... chances are you are going to break them.
Old Apr 26, 2003 | 03:02 PM
HondaJon's Avatar
Default Re: spring install tomorrow (acatak)
You shouldn't have to worry about soaking those bolts, or having them freeze up on you, because from the looks of your signature you have a 2001. Those things shouldn't be locked up already.
I broke both of my rear LCA bolts when I did my 97.
Good Luck,
JP
Old Apr 26, 2003 | 07:14 PM
Default Re: spring install tomorrow (HondaJon)
thanks Guys everything went smooth .
S2000Forsale
Honda S2000
12
Oct 14, 2005 12:56 PM
ityab0y
Suspension & Brakes
12
Jan 6, 2005 09:37 AM
AccrdATK
Nov 4, 2002 05:35 PM
mark72
Sep 15, 2002 11:08 PM
Isaac
Sep 25, 2001 02:58 PM
