Haha... my car doesn't smoke ! BUT.....(56K..hmmm)
Old Apr 24, 2003 | 08:00 PM
TurBoXBirD16's Avatar
Default Haha... my car doesn't smoke ! BUT.....(56K..hmmm)
Hey guys, my final exams are finally over, so I used today to fix my car !! took me total of 5 hours...
So first thing I did was take off the turbo and the downpipe !
Then I started to take off all my charge pipes... you know what I found in them??
OIL OIL OIL OIL !!!! my charge pipe was FULL of oil.. and even the intercooler....
So my first thought is my turbo is dead... so I kept going, take off all my charge pipes, then was going to install the stock header ! But well.. ******* stupid guy sold me the wrong header, so I can't put anything on today.. need to install the header tomorrow, and hopefully I won't see any smoke!
After my turbo stuff, I took my time to install my new bumper with foglights ! with my INTERCOOLER !! Pictures are below. I need to trim very very carefully to keep the stock grill... it's REALLY thin... it will break easily if I push them hard... I was pretty happy with it !
After my bumper, I finally had the time to take off my BIG winter tires, and put back on my summer tires, then I decided to lower my car a bit more.. the results?? see pictures below !
I then started to play around with the turbo, take the downpipes, oil feed line and everything off.
First thing I noticed is that when I then my turbine, it will move... man.. my english sucks, I don't know how to explain, I have taken a movie, so look at it yourself !
http://www.we-todd-did-racing....3D%3D
I also found out the vacuum source on the turbo (which is for the internal wastegate to plug in) there is oil coming out from that hose, how come??
Here are the pictures:
So here are the questions:
1. Is my turbo really bad?? would it be CHEAP to fix??
2. How do I clean my intercooler??? I think there is oil in it.
Thanks !
Cliff: Found out the turbo is bad, installed new bumper, lower down the car, but need to wait for the right header to get the car back to N/A
Old Apr 24, 2003 | 08:09 PM
genop's Avatar
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (TurBoXBirD16)
yup, thats the seals all right. try http://www.cheapturbo.com for a price on a rebuild. Not really sure about the intercooler though.
Old Apr 24, 2003 | 08:16 PM
Ivan's Avatar
senior gold member
Man I'm rooting for you. I hope your doesn't smoke. Keep us updated.
Old Apr 24, 2003 | 08:18 PM
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (Ivan)
did you take your turbo off yet???
just take it off, and then you will know if it's the turbo or the engine...
does your car smoke when driving?? coz my car smokes ANYTIME....
can i fix the turbo by myself?? man.. few hundred bucks.. i don't know if I can afford it !
thanks
Old Apr 24, 2003 | 10:11 PM
SiR Kid's Avatar
New User
OUCH.. Your bearings and seals are gone.
That shaft play shows that the thrust bearings are toast.
Old Apr 24, 2003 | 10:35 PM
woopdedoo
Guest
Posts: n/a
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (SiR Kid)
Easy rebuild, buy yourself a rebuild kit, new bearings, seals, etc. About $80 from Turbonetics.
Old Apr 24, 2003 | 11:21 PM
shortyz's Avatar
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (vtec-elcamino)
a rebuild kit does not come with bearings and if it does it needs to be sent in to have them put in and balanced.
why is there oil on your fmic? did it just leak onto it? or is there a hole?
Old Apr 25, 2003 | 12:00 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (shortyz)
another thing to consider is a catch can, turbo systems are notorious for sucking oil out of the engine into the charge piping.
stan
Old Apr 25, 2003 | 01:34 AM
Cyber ITR's Avatar
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (90crxsi)
to clean ur intercooler just hose it off with hot water
Old Apr 25, 2003 | 06:03 AM
QCKGSR's Avatar
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (SEX DR)
ouch!!
Old Apr 25, 2003 | 06:31 AM
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (QCKGSR)
so i have to send it to rebuilt, eh??
thanks guys
yes OUCH !
EDIT: Coz my turbo was blowing oil into my charge pipes, then got into the intercooler, so I think oil is in there....
Old Apr 25, 2003 | 07:33 AM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEX DR &raquo;</TD></TR><TR><TD CLASS="quote">to clean ur intercooler just hose it off with hot water</TD></TR></TABLE>
i dont think this would work, especially if the oil is INSIDE the intercooler. the best thing you can do is turn it on end and fill up the tank with degreaser of some type. then you'll probably have to force air in there to move the degreaser along and also to dry it out in the end. for this, make some kind of adapter and use an air hose from a compressor, or use a shop vac in reverse where it blows air. the adapter could be as simple as a towel wedged in there, as long as air doesnt leak out.
good luck
Old Apr 25, 2003 | 08:54 AM
Tomek's Avatar
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (keebler65)
you can clean the ic with gasoline too, thats how i cleaned mine.....just pour it through the inlet mix it around a bit and watch how black it is when it comes out of the outlet
Old Apr 25, 2003 | 10:43 AM
JRSCCivic98's Avatar
Default Re: Haha... my car doesn't smoke ! BUT.....(56K..hmmm) (AztecEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AztecEJ &raquo;</TD></TR><TR><TD CLASS="quote">you can clean the ic with gasoline too, thats how i cleaned mine.....just pour it through the inlet mix it around a bit and watch how black it is when it comes out of the outlet </TD></TR></TABLE>
Yeah, but you will run rich for a few miles afterwards from all the gas in there...
Gasoline... A Million and One Uses and Counting!
Old Apr 25, 2003 | 05:06 PM
Ivan's Avatar
senior gold member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">did you take your turbo off yet???
thanks
</TD></TR></TABLE>yeah I did and ran it open header and it doesn't smoke. I guess it was my turbo
Old Apr 25, 2003 | 05:26 PM
94dxt's Avatar
gas the bitch
Old Apr 26, 2003 | 06:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">yeah I did and ran it open header and it doesn't smoke. I guess it was my turbo</TD></TR></TABLE>
good to hear
maybe you should drve it around as n/a for now.. and see how stuff goes..
good luck
Coheed
Sep 29, 2009 04:07 PM
crvtkllr
Apr 29, 2007 01:33 PM
prelude10psi
Dec 12, 2005 06:42 PM
blaze the chemi
May 16, 2005 07:21 AM
technine
May 27, 2003 03:23 PM
