inner diameter of the greddy oil return line hose?
just like the topic says. I'm going to go get a new hose but I need to know the inner diameter or maybe even the outer diameter of the greddy kit oil return line for the GSR.
-10AN will work if you're replacing the fitting on the oil pan as well as the turbo to accept that type of fitting. AN fittings seal the best. However, if you're looking for hose that will slip over the return fittings that come with the Greddy kit, -10AN has too small of an inside diameter. The stock Greddy hose has an inside diameter of 16mm, which is .63 inches. -10AN hose has an inside diameter of .56 inches. It won't stretch with the stainless braid. I've tried it, trust me. Aeroquip does sell a socketless hose in size -10, but strangely it has an inside diameter of .63(16mm) if you need quality push on hose. Make sure you use some kind of thermal protection like firesleeve on the outside of either the stainless braid or the socketless. They both have a temperature rating of 300 degrees and need something so they don't melt.
ill probobly be going to a regular hose shop. there are a couple shops nearby with silly names such as "Hose Pros" and "Hose Man"
I will be using the stock Greddy fittings. I'm guessing I should be ok if I can find a high temp hose with an inner diameter of 16mm I should be cool as long as I use thermal wrap?
If you can find some decent hose down the street and use thermal wrap you should be fine. If it helps any, the hose that came with the Greddy kit is made by Bridgestone.
KDoGx504
Oct 27, 2005 11:33 AM
Cee_mon
Mar 15, 2005 05:27 AM
