99 Honda Civic vibration upon acceleration everytime when I'm completely stopped...help???
check to see if the resonator is unhooked..mine did the same thing...try it... or if any part of the midpipe is hitting the body....
hope i helped
hope i helped
It's the wider section of your exhaust piping before the muffler, and in front of the Cat.
do you have an aftermarket exhaust?
if you do check to see if the pipe is rubbing on the heat shields...if you have an old radiator hose cutt it up and put it in between...gettho but it worked for me
stoneyb245
Jan 18, 2009 07:26 AM
DjTravisKnox
Dec 2, 2001 06:21 PM
