Valve Cover Replacements
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC »</TD></TR><TR><TD CLASS="quote">i would recommend using a new valve cover if you are removing yoru existing one.</TD></TR></TABLE>
New valve cover? You mean gasket right? heh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANCISCO FLORES »</TD></TR><TR><TD CLASS="quote">they run around $30 dollars
and if they are not toasted they dont rip
but better be safe than sorry right
Where the hell are you buying yours from? I got an OEM gasket for a Type R for 12 bux at the acura dealer. With hookup I got one for my GSR for 8 dollars.
30 bux I think I could've got a head gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon »</TD></TR><TR><TD CLASS="quote">i got charged twenty some odd dollars for mine as well, but thats the valvecover gasket and the little ring ones for the spark plug area. </TD></TR></TABLE>
you do your valve adjustment yet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed »</TD></TR><TR><TD CLASS="quote">
New valve cover? You mean gasket right? heh</TD></TR></TABLE>
Oops, i meant gasket. thanks...
if we had to change valve covers that much, i'd consider getting another car all together
Aftermarket ones are more expensive than OEM ones for some reason. OEM does add up close to $30 if you get the spark plug grommets too.
I was thinking about using some engine degreaser diluted in water to clean the gasket and then drying it out. Clean the mating surfaces with acetone and then don't forget to use Honda Bond or RTV sealant on all four cam caps. I think this would work out well.
