Valve Cover Replacements
Old Apr 24, 2003 | 01:46 PM
ITR00-1200
Guest
Posts: n/a
Default Valve Cover Replacements
Is it required or necessary, or should I say recommended to change out the gasket when replacing valve covers?
Old Apr 24, 2003 | 01:48 PM
Seedc2's Avatar
Default Re: Valve Cover Replacements (ITR00-1200)
you should have one for backup in case you rip it. Otherwise you can reuse your old one
Old Apr 24, 2003 | 02:00 PM
ITR00-1200
Guest
Posts: n/a
Default Re: Valve Cover Replacements (kendogg)
I see. How much do they run for by the way?
easy to rip?
Old Apr 24, 2003 | 02:04 PM
mr.beeks's Avatar
they run around $30 dollars
and if they are not toasted they dont rip
but better be safe than sorry right
Old Apr 24, 2003 | 06:09 PM
IntEGNYC's Avatar
Default Re: Valve Cover Replacements (FRANCISCO FLORES)
i would recommend using a new valve cover if you are removing yoru existing one.
Old Apr 24, 2003 | 06:37 PM
ragejed's Avatar
Default Re: Valve Cover Replacements (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">i would recommend using a new valve cover if you are removing yoru existing one.</TD></TR></TABLE>
New valve cover? You mean gasket right? heh
Old Apr 24, 2003 | 07:42 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANCISCO FLORES &raquo;</TD></TR><TR><TD CLASS="quote">they run around $30 dollars
Where the hell are you buying yours from? I got an OEM gasket for a Type R for 12 bux at the acura dealer. With hookup I got one for my GSR for 8 dollars.
30 bux I think I could've got a head gasket.
Old Apr 24, 2003 | 10:23 PM
tC_Dragon's Avatar
Default Re: Valve Cover Replacements (P1mpSlap)
i got charged twenty some odd dollars for mine as well, but thats the valvecover gasket and the little ring ones for the spark plug area.
Old Apr 24, 2003 | 10:24 PM
Aaron M's Avatar
Default Re: Valve Cover Replacements (pdcdragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon &raquo;</TD></TR><TR><TD CLASS="quote">i got charged twenty some odd dollars for mine as well, but thats the valvecover gasket and the little ring ones for the spark plug area. </TD></TR></TABLE>
you do your valve adjustment yet?
Old Apr 24, 2003 | 10:41 PM
tC_Dragon's Avatar
Default Re: Valve Cover Replacements (SilverB18C1)
nope.. bought it wit scott to get ready for when we do haha...
Old Sep 3, 2003 | 08:22 AM
IntEGNYC's Avatar
Default Re: Valve Cover Replacements (ragejed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">
New valve cover? You mean gasket right? heh</TD></TR></TABLE>
Oops, i meant gasket. thanks...
if we had to change valve covers that much, i'd consider getting another car all together
Old Sep 3, 2003 | 01:26 PM
Stewie's Avatar
Aftermarket ones are more expensive than OEM ones for some reason. OEM does add up close to $30 if you get the spark plug grommets too.
I was thinking about using some engine degreaser diluted in water to clean the gasket and then drying it out. Clean the mating surfaces with acetone and then don't forget to use Honda Bond or RTV sealant on all four cam caps. I think this would work out well.
RGK500
Feb 15, 2007 08:23 PM
Thanks knightsport!
May 5, 2006 06:31 PM
fanta!
Jul 5, 2005 12:46 PM
stew18564
18
May 8, 2004 09:23 PM
dc0166
Oct 25, 2003 08:13 AM
