I need bigger injectors so I can turn up the boost. ANyone have any?
From: see my earring from a MILE, bling bling, Va, USA
Right now, I have 550's and I would like to run about 24 psi on race gas.
Fully built motor, so thats all good. Any suggestions?
Thanks in advance..
Thanks in advance..
Inlinepro runs FMU 550s and 24lbs all day no problems....talk to Tony (dont know his last name) down in stafford, drives a blue sol, and a red hatch race car... works at protrucks....he'll help you out if u know him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">Inlinepro runs FMU 550s and 24lbs all day no problems....talk to Tony (dont know his last name) down in stafford, drives a blue sol, and a red hatch race car... works at protrucks....he'll help you out if u know him</TD></TR></TABLE>
LOL tony belcastro--
hes one of my best friends.
sweet. he's a cool dude... ur fine with those injectors though. 2 guys at my shop run 440s and 20lbs on c16/93oct 50/50 mix. with 75sprayed...well one guy did, then sold the whole kit to the other guy..lol...now the first guy has a much crucialler (ha) motor...still on 550s though and now like 24lbs./..
RIght right....but they arent using hondata either...they are using FPR and FMU's right? Thats the only wya possible. Cuz i know there is no way in hell ppl are running hondata and boosting 20 psi on 440's. They would max out
either or. The best product I can get for the lowest dollar if possible
Don't use a FMU. Get some 720 or some 880 if you don't want to worry about needing bigger injectors later.
Try http://www.MotorMatrix.com
They will give you a great price!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo »</TD></TR><TR><TD CLASS="quote">880cc injectors, hondata s200, that will easily get you 24psi+</TD></TR></TABLE>
werd thats what im being told. I have 550's now, and i think i MIGHT be able to get like 17 or 18 psi out of them
and since you have hondata, you easily beable to lean them out. I was actually gonna go with 1000cc injectors, I just couldn't afford them.
EDIT: good price motormatrix
Boost is irrelavent. Injectors are a direct function of power production. How much power do you want to make? On most low compression/high efficiency turbo Honda apps, 720cc injectors will be good for about 450whp, 880cc injectors are good for about 550whp. I usually recommend going bigger than what you need without sacrificing idle and drivability (for a street car).
eMpAtHy
Feb 28, 2005 01:28 AM
