will a 90LS o2 sensor fit my 90si?
Old Apr 24, 2003 | 11:08 AM
Charlie Moua's Avatar
Default will a 90LS o2 sensor fit my 90si?
I'm thinking that since they are both OBD-0 they should have the same o2 sensor housing and same bung hole size..... will it clip right on?
Old Apr 24, 2003 | 11:20 AM
slowpokesi's Avatar
Default Re: will a 90LS o2 sensor fit my 90si? (Charlie Moua)
yes
Old Apr 24, 2003 | 11:37 AM
zCivic's Avatar
yeah it will work.
Old Apr 24, 2003 | 12:21 PM
Default Re: will a 90LS o2 sensor fit my 90si? (zCivic)
should i get a OEM one that is from the junk yard/off another car or get a new BOSCH one at AutoZone?
is $30 fair for and OEM o2 sensor....don't know the miles on it though
Old Apr 24, 2003 | 12:26 PM
slowpokesi's Avatar
get the universal one from autozone, and cut the plug and crimp it save 10 bucks?
20 bucks.
Old Apr 24, 2003 | 12:31 PM
zCivic's Avatar
Default Re: will a 90LS o2 sensor fit my 90si? (slowpokesi)
thats what I did.. I think the Bosch universal would be fine, also you can get a heated 3/4 wire and that will cause you to idle better on start up just another suggestion
Old Apr 24, 2003 | 01:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">thats what I did.. I think the Bosch universal would be fine, also you can get a heated 3/4 wire and that will cause you to idle better on start up just another suggestion</TD></TR></TABLE>
who makes the heated 3/4 wire o2 sensor? never heard of that? how much is that & were can i get it?
so there are 2 different types of 02sensors right heated and non-heated?
Old Apr 24, 2003 | 01:36 PM
zCivic's Avatar
you can buy bosch 3 or 4 wire o2 sensors... There kinda $$$$ though. Nissans use a 3 wire or you can get a 4 wire from/for a 92-00 civic. Its pretty basic for wiring, run 1 wire for you 02 sensor (white) take the green and black twist them together and run to a ground then run another wire to a 12 volt switch and thats for a 4 wire. 3 wire should be about the same just 1 for the ECU, a ground and then switched 12volts. There both heated 02 sensors. They will read the same but a heated warms up fast of course and get cold start up idles alot better
98exturd
10
Aug 16, 2007 01:06 PM
SpoolinDa
May 31, 2005 07:34 PM
mugenhatch92
Aug 21, 2004 09:25 AM
bsuperior2
Oct 16, 2003 12:57 PM
IronQQQ
Aug 25, 2003 02:40 PM
