can you by-pass an o2 sensor
HT White Ops
There are plenty of ways (none of them fool-proof) to bypass O2 sensors. Two of the most popular options are a drilled out spark plug non-fouler (called a spoof) and an electronic O2 sensor "simulator".
HT White Ops
Re: (98exturd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98exturd »</TD></TR><TR><TD CLASS="quote">where would i get that stuff and how would you do it. i dont really get what your sayin
O2 simulators are resistor packs that you wire into your O2 harness. Search eBay for "o2 simulator".
Ek Forever y0!
Re: (hatch96y7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">but how can this work for the primary o2 sensor.
and how do u wire it up</TD></TR></TABLE>
Just like it would work for any other spark plug.
Any simulator kit you buy should come with instructions.
It's plug and play usually. The fouler is by far the easiest, it's basically there to gap the o2 sensor so it gets less exhaust readings.
Re: can you by-pass an o2 sensor (98exturd)
The only thing you can use to bypass the primary O2 sensor is a wideband sensor/controller that has a narrow band 'simulated' output.
Darth ModerVader
Re: (hatch96y7)
It can't, as EE_Chris stated.
You can tune the setup to always run open loop, but why are you looking to bypass the sensor in the first place?
Re: (Padawan)
because my harness is fucked up and i cant find the connector for the primary o2 sensor.
and the cat i have doesnt have a 02 sensor hole.
i am running a dx 96 ek wth a obd2a gsr on a p72
i think i have a vx or hx harness so i am lost i have one o2 sensor plug.
i have an extended harness going to the bottom of the header but i am throwing a code for my primary o2 sensor.
so i am thinking i have the secndary o2 sensor hooked up.
mugenhatch92
08-21-2004 09:25 AM
