max hp on 240cc injectors?
Old Apr 24, 2003 | 10:38 AM
fredtoast's Avatar
Default max hp on 240cc injectors?
I know about the problems with high fuel pressure (up to 90), but I need to know what is the maximum hp my stock injectors will support.
Old Apr 24, 2003 | 03:40 PM
B18CXr's Avatar
Default Re: max hp on 240cc injectors? (fredtoast)
@ stock PSI, around 230-240 crank hp
Old Apr 24, 2003 | 04:54 PM
turbotypeR@SPEC's Avatar
25 Year Member
with boost and an fmu i have seen around 300whp
Old Apr 24, 2003 | 05:25 PM
Batoutahell's Avatar
Default Re: max hp on 240cc injectors? (turbotypeR)
Wow, 300 whp on 240cc injectors? I know that mine were at 100% duty cycle at 218whp. I tried to add fuel, and there just wasn't any more room.
Old Apr 24, 2003 | 07:38 PM
baonest1's Avatar
Default Re: max hp on 240cc injectors? (Batoutahell)
sorry to hijack, but with a 190 fuel pump and 270cc injectors. can i run up to 70psi if i have to?? whats the highest i can do without causing probs. its for 2.0L ls/vtec.
Old Apr 24, 2003 | 11:42 PM
austrian type-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">with boost and an fmu i have seen around 300whp</TD></TR></TABLE>
ah camon, thats bullshit.
370cc are maxed out with 300whp
Old Apr 25, 2003 | 04:30 AM
25 Year Member
Default Re: max hp on 240cc injectors? (austrian type-R)
not bullshit.i said with an fmu.a 12:1 fmu.
Old Apr 25, 2003 | 04:35 AM
more fuel press does not mean more fuel in the combustion camber, thats physic.
on stock ITR engine the 240cc are about 95% dutycycle.
Old Apr 26, 2003 | 04:58 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">more fuel press does not mean more fuel in the combustion camber, thats physic.</TD></TR></TABLE>
Come on guy,
More pressure = higher flow rate = more fuel in combustion chamber given same pulsewidth
at stock pressure the last car i tuned was running 95% duty at 190whp.
Old Apr 28, 2003 | 12:01 PM
fredtoast's Avatar
Default Re: max hp on 240cc injectors? (sgT)
What about the 290cc prelude injectors? How much horsepower can they handle, abd how much should I pay for a used set?
Old Apr 28, 2003 | 12:11 PM
01ITR#700's Avatar
FWIW I've seen nearly 300whp with an FMU and stock injectors...Is it safe? No. Have I seen it with my own eyes? Yes. Did my car make 282whp with stock injectors and an FMU? Yes.
HTH
Mark
ej8
Jul 30, 2007 03:20 AM
Tex Blackwell
May 6, 2004 03:45 AM
GOLDBERG
Apr 13, 2003 05:16 PM
BoostedD15B7
Sep 26, 2002 01:15 PM
ludelvr
Dec 19, 2001 07:50 AM
