Going Through Alternators Like Water
Old Apr 24, 2003 | 07:22 AM
EF8_SiR's Avatar
Default Going Through Alternators Like Water
At first I thought it was just faulty alts (I believe 2 of em were), but going through 5 within one yr's period, there's somethign seriously wrong. With B16A1 (in CRX), I know u can choose between the 90-91 teg or 95 DelSol DOHC Vtec model, so I went with the Delsol model. I dunno if this is causing the problem or something else with my electrical system. It's more of a matter of annoyance to havign to keep changing alts more then anything.
Can anyone suggest possible reasons behind all these alt replacements. BTW, my alt pulley also has a little dent on it but I don't think that is causing all these probs....
thx
Old Apr 24, 2003 | 08:53 AM
Stew Pidasso's Avatar
Default Re: Going Through Alternators Like Water (EF8_SiR)
Is it a mechanical failure or an electrical failure?
Old Apr 24, 2003 | 10:42 AM
GZERO's Avatar
not sure about hondas but how about voltage regulator or a faulty battery?
Old Apr 24, 2003 | 10:51 AM
02zx2bkleen's Avatar
Default Re: Going Through Alternators Like Water (GZERO)
you didnt say if it failed mech or elec! if it failed mech(bearings?) i would say that your small dent even if small at 4000+ rpm could be enough to create an oscillation that could chew up your bearings...heard of that b4 anyway. im also wondering if you have a system. do ya? then our problem gets more complicated!
then it could be as simple as something like a bad ground. i dont know 2much about elec on these cars, but i nkow there are self-exciting and non"""type alts.
i cant tell you exactly what that means, but i know you cant substitute one for another-dont know if honda uses both kinds....hmmmm? maybe if you give us more info we can help
Old Apr 24, 2003 | 11:12 AM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_SiR &raquo;</TD></TR><TR><TD CLASS="quote">At first I thought it was just faulty alts (I believe 2 of em were), but going through 5 within one yr's period, there's somethign seriously wrong. With B16A1 (in CRX), I know u can choose between the 90-91 teg or 95 DelSol DOHC Vtec model, so I went with the Delsol model. I dunno if this is causing the problem or something else with my electrical system. It's more of a matter of annoyance to havign to keep changing alts more then anything.
thx
i guess after wasting all the money on the alternators, why didn't u just invest in a new pulley if you knew it was dented???
Old Apr 24, 2003 | 11:31 AM
EF8_SiR's Avatar
Default Re: Going Through Alternators Like Water (MikeMAN)
It would be an electrical failure. Mech wise, the bearings and so forth all look alright. As for the pulley, I am looking for an aftermarket one as of moment...
But actually I found out what happened. The person who put my alt in last put in a D series instead of B series due to fitment issues. So now i gotta find time to hammer the wall to make the b18a pulley fit.
Anyways, thx for the responses.
PS&gt; Know anyone selling an aftermarket alt pulley for cheap?
Old Apr 24, 2003 | 02:46 PM
MikeMAN's Avatar
good luck and hope you get ur problem fixed!
mike
Old Apr 24, 2003 | 05:09 PM
fsarfino's Avatar
Hey I had the same problem when I had my 91 CRX w/ B16A. The conclusion I came to is the alternators from parts stores suck. After I bought 1 from honda I never had that problem again. BTW the alternator from the dealer was around $300.00
Intercooler
Audio / Security / Video
19
Sep 29, 2005 09:10 PM
NFM_Dm
13
Nov 16, 2004 08:15 PM
PM-Performance
Apr 15, 2004 07:21 AM
EF8_SiR
Apr 24, 2003 11:32 AM
ZoNe_HKS
Jun 30, 2002 08:10 AM
