HID Problems Help (ITR Related) :Searched ***pics***
Old Apr 23, 2003 | 07:07 PM
TypeR 01 886's Avatar
Default HID Problems Help (ITR Related) :Searched ***pics***
I have just purchased a second hand HID kit the trvor sold (4300k)
Two problems.
1: There is a broken notch on the light
Here is what its supposed to look like
Have any of you ever experienced this? Also how much will this affect
me and what should I do? Will this be a big problem?
2: Can u all post pics where u have mounted your ballasts.(or at least explain?
Prefrebly the drivers side ones (USDM)
Thank u all in advance!!!
Old Apr 23, 2003 | 07:28 PM
xanctus's Avatar
Default Re: HID Problems Help (ITR Related) :Searched ***pics*** (TypeR 01 886)
I actually had that kinda prob. where the notch is broken. But I don't think that will give you any big problem.
Did u get it broke? or did you break it accidentaly?
regarding your 2nd question,
this is where I put my ballast
Old Apr 23, 2003 | 07:39 PM
Default Re: HID Problems Help (xanctus)
Thanks for the reply.
1: The notch was broken from the person I purchased the kit from
2: I would love to mount my ballast there but my alarm "speaker"
resides there. (ANY OTHER PLACES??)
TY All
Old Apr 23, 2003 | 07:58 PM
^bump
Old Apr 23, 2003 | 08:03 PM
B2FiNiTY's Avatar
Default Re: HID Problems Help (TypeR 01 886)
You can put it next to the engine mount. It is wedged in there pretty tight
Old Apr 23, 2003 | 10:28 PM
Calavera's Avatar
Default Re: HID Problems Help (B2FiNiTY)
If I remember correctly, there are two other notches so the bulb wouldn't really pop out accidentally. You're fine as far as I can tell.
Old Apr 24, 2003 | 08:52 AM
Default Re: HID Problems Help (Calavera)
Thanks for the replies... anybody know where I can get those Audi A6 projectors for cheap now
Old Apr 24, 2003 | 09:06 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">I would love to mount my ballast there but my alarm "speaker"
resides there. (ANY OTHER PLACES??)</TD></TR></TABLE>
Behind the bumper cover would be my suggestion.
Old Apr 24, 2003 | 09:18 AM
skafia's Avatar
25 Year Member
Default Re: HID Problems Help (Padawan)
If you take your front bumper off and look inside the driver's side fender, there's 2 holes down there where you can mount a custom made bracket. That's what I plan on doing.
Thd passenger HID ballast fits well under the ABS bracket, and as for the right one, it goes here on mine:
Old Apr 24, 2003 | 09:19 AM
skafia's Avatar
25 Year Member
Default Re: HID Problems Help (skafia)
BTW - Is this second hand HID kit made to fit into a 9006 housing?
If it is, then you can't use these bulbs with Audi A6 Projectors.
Old Apr 24, 2003 | 11:52 AM
GeorgeY's Avatar
Hey. I accidently broke that exact same peice. The problem you will encounter is the light will not turn on right away and during hard bumps the bulb light will cut off. Kinda annoying. NE ways what I did was i switched the busted bulb to my drivers side and there are enough things around that i twist tied the bulb on tightly. Since then no problems. Email me for some pics.
Old Apr 24, 2003 | 12:09 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">BTW - Is this second hand HID kit made to fit into a 9006 housing?
If it is, then you can't use these bulbs with Audi A6 Projectors.</TD></TR></TABLE>
correct. You can, however, buy projectors with some D2S bulbs in a package or seperately and you'd be set.
And that's a trevor kit so those are D2S bulbs modified to fit 9006 housings.
Default Re: HID Problems Help (GeorgeY)
What is the proper way to clean the bulbs? Alcohol, is there any special procedure?
Old Apr 24, 2003 | 12:10 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">What is the proper way to clean the bulbs? Alcohol, is there any special procedure?</TD></TR></TABLE>
denatured alcohol is what I used to clean the bulbs.. no real special procedures..
Old Apr 25, 2003 | 12:42 PM
Default Re: HID Problems Help (dawhiteboy)
Ok, I have just got the lights and now they are installed. I was going to ask you all with HIDs, how do you have the bulbs placed inside the projector?
Which way is the "electrode" facing? up/down? I have seen it on the
board before but I cant find it now.
CJ0
Nov 17, 2007 11:46 AM
Devine
Nov 28, 2005 02:31 PM
NSTY Z33
Aug 5, 2004 09:42 PM
jumpmann23
19
Jun 7, 2004 01:43 PM
Dynamix
Mar 3, 2003 08:50 AM
