I want to make my civic Si fast!
Old Apr 23, 2003 | 02:23 PM
d16a6's Avatar
Default I want to make my civic Si fast!
I have a civic Si(d16a6) and I want more proformance. I want to run low 15´s high 14´s in the 1/4 mile. Whats the recepie for that? Cams? Header? CAI?
Kind regards
Old Apr 23, 2003 | 02:41 PM
sslude's Avatar
Default Re: I want to make my civic Si fast! (d16a6)
wahts your spending range? have you figured out if you have wanted to go fi or all motor? a good shot of nitrous should do it.
NA- I/H/E, thinner headgasket, cams, vavle springs and retainers (if you want to rev higher safely), cam gears, port and polish and a good tuner..that would be a pretty nice setup.
Old Apr 23, 2003 | 02:48 PM
Ronin Panda's Avatar
Default Re: I want to make my civic Si fast! (sslude)
Motor Swap!!
Old Apr 23, 2003 | 02:49 PM
bfrank81's Avatar
Default Re: I want to make my civic Si fast! (Touge Panda)
Whats your price range? that pretty much controls everything about how fast you are going to go.
Old Apr 23, 2003 | 02:50 PM
slowman's Avatar
I took way too long
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16a6 &raquo;</TD></TR><TR><TD CLASS="quote">I have a civic Si(d16a6) and I want more proformance. I want to run low 15´s high 14´s in the 1/4 mile. Whats the recepie for that? Cams? Header? CAI?
Kind regards
I have this on my D16A6
I/H/E, Crane Stage 2 Cam, skunk2 adjustable cam gear (3* adv). You can see a vid in my sig if you want.
But if you want those numbers (which those numbers are my quest, too):
Do what's stated above and:
Upgrade you valvetrain
Raise CR
Port and polish head
Hondata or some kind of reflash...
That should put you well into the 15s if not 14s.
Old Apr 23, 2003 | 03:00 PM
d16a6's Avatar
the price range is 2500$ and i want to go N/A no gas or turbo.
Old Apr 23, 2003 | 03:08 PM
sslude's Avatar
Default Re: (d16a6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16a6 &raquo;</TD></TR><TR><TD CLASS="quote">the price range is 2500$ and i want to go N/A no gas or turbo.</TD></TR></TABLE> I/H/E, cams, cam gears, tuning..that should get you closer. but you'll need more money.
Old Apr 23, 2003 | 03:10 PM
FullMetalJacket's Avatar
Default Re: (d16a6)
well like the one dude said..get a crane cam stage 2 or so...Good clutch...DC or good Name brand header and exhaust (stay away from ebay ****) cam gear can help,stiff *** springs to help with weight transfer. I suggest Skunk 2 adjustables..bigger injectors may help. Also when you a cam get ur head checked by a machine shop and you realy must install good vlave springs or else you will get valve float..also gutt the interior definately it its a hatch Si.. a CRX probably wouldnt need to be gutted as much. You may want to get LSD in your trans so you can hook up and maybe small slicks. The smaller diameter tire will help you accel a lil faster. thats all I can think of. Good luck. I was gonna go this route but i think Ill go b series instead
Old Apr 23, 2003 | 03:11 PM
d16a6's Avatar
Default Re: I want to make my civic Si fast! (slowmanEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEF &raquo;</TD></TR><TR><TD CLASS="quote">
Raise CR
That should put you well into the 15s if not 14s. </TD></TR></TABLE>
Raise CR whats that?
Old Apr 23, 2003 | 03:12 PM
ExospeedAMcrx's Avatar
For $2500, I can get you in the high 13's, low 14's full interior.
like the previous posts said, it all depends on how much you want to spend.
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: (FullMetalJacket)
B16
Old Apr 23, 2003 | 03:27 PM
Kris's Avatar
Default Re: (d16a6)
You can do a full b16 swap for that much plus have some money left over for some other mods and a burrito at taco bell.
Old Apr 23, 2003 | 05:10 PM
slowman's Avatar
I took way too long
Default Re: (Kris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kris &raquo;</TD></TR><TR><TD CLASS="quote">You can do a full b16 swap for that much plus have some money left over for some other mods and a burrito at taco bell.</TD></TR></TABLE>
Yep, and still be a b16 running the same b16 times. Run a 13 with an A6 and that's something to brag about if you ask me. And raise CR is raising the compression ratio (CR). This can be done by milling the head or a thinner head gasket or different pistons.
Old Apr 23, 2003 | 05:25 PM
CLICC916's Avatar
Default Re: (slowmanEF)
we'll all assume you don't care about smog from where you're from either? if you don't....just get a wicked head package like everyone has said
Old Apr 23, 2003 | 08:16 PM
Default Re: (CLICC916)
I actualy think you should run a turbo. Its cheap for a junkyard set up. maybe even tear the block apart and lower the compression with some dished pistons and raise the boost but you said you wanted n/a but i thought i should mention the turbo.
Old Apr 23, 2003 | 08:29 PM
Josh717's Avatar
B16A w/tranny ecu-1200
Generic mounts, DIY shift linkage-400
I/H/E-400
Nitrous-500
______________2500 total
Kicking V8 mullet ***---PRICELESS
Old Apr 23, 2003 | 09:35 PM
h45454's Avatar
d16a1 pistons are a cheap way to up compression
Old Apr 23, 2003 | 10:53 PM
SmobbinSi's Avatar
I know a few people with 4th gen Civic/CRX that can hit mid to high 14s with just i/h/e, and a Gude head package.
This is with street tires and not very stripped.
I myself had a CRX with over 200,000 miles on the original stock motor with just a cam and hit a 14.82@93. The four other mods my 89 had was an HKS intake, DC Fab header, HKS exhaust, and a test pipe.
Everything else was original from the factory: spark plugs/wires, clutch(this was the 2nd clutch, Honda OEM), intake mani, throttle body, ecu, ignition.
Too bad I totalled my baby last November, but I did save her "heart", and it will be going into Old Yella, who will be debuting at a West coast drag strip by this summer!!! WOO-HOO.
Anyways, the point of my post is that you don't have to spend much to make your d16a6 fast as what you are shooting for.
Old Apr 24, 2003 | 07:24 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEF &raquo;</TD></TR><TR><TD CLASS="quote">Yep, and still be a b16 running the same b16 times. Run a 13 with an A6 and that's something to brag about if you ask me. </TD></TR></TABLE>
Is running B16 times necessarily a bad thing? Sure it can be disappointing if you can't run the numbers other people are with the same engine or less mods, but think how much worse you'd feel if you pumped all that money into the A6 only to have a mid-to-high 15 second car. I've seen it happen.
Old Apr 24, 2003 | 10:11 PM
SmobbinSi's Avatar
Default Re: (raene)
I have seen a lot of the opposite at the tracks I go to (Pomona, Famoso, Sears, Sac): 4th gens with a swap hitting mid to high 15s
Old Apr 25, 2003 | 03:39 AM
Charlie Moua's Avatar
fucken do search bro! there are well over 10post about makeing the D16a6 fast!
Old Apr 25, 2003 | 11:27 AM
[626]phixionEF91's Avatar
Default Re: I want to make my civic Si fast! (Charlie Moua)
b20
cams of some sort
new valve springs
cai
dc sport or airmass headers (jasmine if your lucky)
2.5 exhaust piping
no cat
es oval muffler
port and polish
forged pistons
make sure suspension is straight
this is my fantasy formula, but im sure this would probly get you in the high 14 or 13's
Old Apr 25, 2003 | 12:45 PM
Si-Yaaa!'s Avatar
Default Re: I want to make my civic Si fast! (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">For $2500, I can get you in the high 13's, low 14's full interior.
like the previous posts said, it all depends on how much you want to spend.</TD></TR></TABLE>
Get exospeeds head package and a bisi header/intake/exhaust and I think you'd be happy. I wish someone would do this and get some 1/4 mile times so I can stop debating wether or not to do a swap. But I'll probably end up with a b16a because of the future possibilites of it. But everyones different.
Old Apr 25, 2003 | 03:41 PM
raene's Avatar
Default Re: (SmobbinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmobbinSi &raquo;</TD></TR><TR><TD CLASS="quote">I have seen a lot of the opposite at the tracks I go to (Pomona, Famoso, Sears, Sac): 4th gens with a swap hitting mid to high 15s </TD></TR></TABLE>
Oh I agree! People finishing a swap, coming out and running some poop times... but that's a can't-drive factor, not a has-the-potential factor
Personally I agree with the above response, go with the exospeedAMcrx package, can't go wrong there... that setup would definitely rip.
warpigtype-s
12
Oct 18, 2007 04:19 PM
civic_jdm16
Jan 20, 2007 02:43 PM
ne3ek
Feb 21, 2006 08:06 AM
d16a6
Apr 23, 2003 04:26 PM
Toretto
Jun 6, 2002 05:02 PM
