A2 head on A3 block?
Old Apr 23, 2003 | 08:41 AM
1abSi's Avatar
Default A2 head on A3 block? **more ? info at bottom**
any of you EP3's out there done this yet??? and if you know of anyone, can you please give me their contact info..thanks!
Modified by 1abSi at 12:40 PM 4/28/2003
Old Apr 23, 2003 | 12:34 PM
ATYPR's Avatar
Default Re: A2 head on A3 block? (1abSi)
You can get a complete k20a2 for $2500 to $3000.
Old Apr 23, 2003 | 01:18 PM
1abSi's Avatar
Default Re: A2 head on A3 block? (FUCATYPR)
i have "heard" of a deal like that but i would have to see it to believe it...plus i mean i have seen the head for sale for like 600-700 and then the ecu for like 250....then you can get the flash.....i mean the blocks are relatively similar and i don't want 6-speed(which usually won't come with the motor for that price).
Old Apr 23, 2003 | 07:34 PM
Big Money D's Avatar
I have bought the head and ecu already but may go another route so I might sell them if you are interested plus I am in Fl too and could deliver
Old Apr 23, 2003 | 07:49 PM
1abSi's Avatar
Default Re: A2 head on A3 block? (01-1004R)
i pmed you justincase you didn't get it
Old Apr 24, 2003 | 04:00 PM
flu1512's Avatar
New User
Whats the word?
can the A2 head be swapped over easily?
Old Apr 24, 2003 | 04:58 PM
taikahn's Avatar
Default Re: (flu1512)
damnit, tell us! --- j/k
I dont think its been done yet... Ive been lurking on these boards for a while and I haven't seen it done, only talked about...
Old Apr 24, 2003 | 05:29 PM
Default Re: (taikahn)
yes the a2 head is a simple and straightforward swap on the a3 block
aj-racing has already done the swap as well
Old Apr 24, 2003 | 05:50 PM
flu1512's Avatar
New User
Thanks, 01-1004R
Do you know where I can read more about it?
Old Apr 24, 2003 | 06:41 PM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1abSi &raquo;</TD></TR><TR><TD CLASS="quote">i have "heard" of a deal like that but i would have to see it to believe it...plus i mean i have seen the head for sale for like 600-700 and then the ecu for like 250....then you can get the flash.....i mean the blocks are relatively similar and i don't want 6-speed(which usually won't come with the motor for that price).</TD></TR></TABLE>
Here you go!! A K20a2 for $2500!!
Call these guys 1-800-695-1021
What about $3000??? 1-800-797-4595
Have fun!!!
Old Apr 24, 2003 | 06:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flu1512 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, 01-1004R
Do you know where I can read more about it?</TD></TR></TABLE>
they talked about it in the thread " read this 200hp upgrade for ep3" I had it bookmarked but is says it no longer exists so I don't know what happened to it
you can im aj power he is the one that did the swap
and like I said I have the type s head and ecu for sale if it is something you are interested in
Old Apr 25, 2003 | 12:08 AM
flu1512's Avatar
New User
Damn, I remember seeing that thread just a while ago too, I should have read it closely.
Does anyone remember if it was a simple swap? Or did it require some modification?
Old Apr 25, 2003 | 04:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flu1512 &raquo;</TD></TR><TR><TD CLASS="quote">Damn, I remember seeing that thread just a while ago too, I should have read it closely.
no modification needed as simple as straightforward as b series swap
Old Apr 25, 2003 | 06:59 AM
fireant's Avatar
Default Re: (01-1004R)
Man we need some freakin details, youd think this would be a really good bang-for-buck setup, right?
Old Apr 28, 2003 | 08:39 AM
1abSi's Avatar
"ok i am not an expert in engines just around a little bit to be able to know a thing or two. however, honda did make a fully counterweighted crank for the type s, as opposed to our balanced crank. why? thats why cranks have to be at least balanced. any little vibrations could result in big damage thats why its really important. very sensitive. when it is fully counterweigted and stuff it is more equipped (in general) to handle a beating. some engines are equipped with crankshaft counterweights in order to reduce torsional vibrations. i guess if it goes to 7900RPM and produced 200HP it probably needs it. ALSO the type s has stronger bigger rods/piston assembly. Its not just one thing its a few and they're all expensive. "so what do you all think about this??? does this mean that setup without modding the block is a bad idea?
Old Apr 28, 2003 | 12:16 PM
fireant's Avatar
That's a good point, and if its true, it would apply to Hondata too.
Old Apr 28, 2003 | 01:29 PM
1abSi's Avatar
Default Re: A2 head on A3 block? (hatch2k)
yeah that's what i was thinking, but i have yet to hear of ANYONE that had a prob with hondata
Old Apr 28, 2003 | 01:32 PM
fireant's Avatar
I can wait a year to find out, before I go with anything radical. In the meantime, theres lots of other ways to add some hp to the stock setup.
Old Apr 28, 2003 | 02:17 PM
PhxK20a3's Avatar
My A3 has fuel cut at 7900 according to the charts i have.It dosent even seem like its stressing the motor one bit,so i dont see how 7900 with an a2 head is any different.
1abSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR &raquo;</TD></TR><TR><TD CLASS="quote">
Have fun!!!</TD></TR></TABLE>well dood i called the second # (first was closed) and they quoted me 4500....have you called these people before??? or did you just "hear" that?.....
TriedAndTrue
Oct 15, 2011 08:39 PM
88 EF Hatch
Jun 12, 2010 02:37 PM
1991hb
Mar 9, 2007 12:45 PM
Turbo_y8
Feb 25, 2006 10:10 PM
Convoy
Jan 26, 2004 07:01 PM
