b20vtec, goin all motor.......who has one or who can gimmie some advice about em'?
Old Apr 22, 2003 | 10:33 PM
MikeMAN's Avatar
Default b20vtec, goin all motor.......who has one or who can gimmie some advice about em'?
well i got my swapped in this past friday. i get a CEL 45(too rich/too lean code) so im getting a fpr because i suspect the engine is thirsty because its used to b20 or vtec, not both. I have a crappy AEM CAI (made for SOHC) that is my only mod (had it since i bought the car, never bought a bigger one for the new engine). I have the low compression b20b with b16 head. I was wondering could I possibly make 200whp on the low compression? Looking for a daily driven low 13 second car on street tires.
What would u suggest for the next mod?(btw: i don't need to get emissions tested so testpipes/etc..are very possible solutions)
header
exhaust
test pipe
pistons(11.5:1 cr)
cams/valvetrain
new CAI
thanks guys!
mike
Old Apr 23, 2003 | 07:34 AM
Blaze45's Avatar
Brrraaaap!
Default Re: b20vtec, goin all motor.......who has one or who can gimmie some advice about em'? (MikeMAN)
Theres this thing called search. and I must say it works wonders.
Good Luck
Blaze
Old Apr 23, 2003 | 11:37 AM
Jeff C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">I have the low compression b20b with b16 head. I was wondering could I possibly make 200whp on the low compression?</TD></TR></TABLE>
Well according to this, its possible. However, it does not say which block they are using. What I suggest is to look around and find some crvt's or even lsvt's that have hit 200whp and see what they used to achieve that.
Old Apr 23, 2003 | 08:47 PM
MikeMAN's Avatar
Default Re: b20vtec, goin all motor.......who has one or who can gimmie some advice about em'? (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Theres this thing called search. and I must say it works wonders.
Good Luck
Blaze</TD></TR></TABLE>
give me a big fat ******* please thanks, come again.
mike
Old Apr 23, 2003 | 08:50 PM
MikeMAN's Avatar
Default Re: b20vtec, goin all motor.......who has one or who can gimmie some advice about em'? (Jeff C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff C &raquo;</TD></TR><TR><TD CLASS="quote">
thanks,
mike
Old May 1, 2003 | 11:35 AM
ooairewreckoo's Avatar
bump for you mike, im wondering the same exact thing. i got a b20b4 and a gsr head, im basically on the same boat your on. im wondering if its gonna be hard to get to 200 whp. CAN ANYONE OUT THERE ANSWER THIS QUESTION?????
Old May 1, 2003 | 04:41 PM
mr. wu's Avatar
Default Re: b20vtec, goin all motor.......who has one or who can gimmie some advice about em'? (ooairewrecko
i have had my b20 vtec for about four months now, and i am running crower stage 3 cams skunk2 manifold 70mm throttle body electric water pump port an polished head with 3 angle vavle grind and oversized valves 370cc injectors and afew other random parts. i dont even think that mine is making 200 hundred horse power and if it is, i don't htink it is much more than that.
Old May 2, 2003 | 06:51 AM
wow are you serious. barely or not even 200 horses with all those mods? thats crazy
so basically you get rocked by other b series motors with the same mods???man im losing hope and my car is getting the swap done as of today. .. what ecu are u running wu??
oh check the dyno over at importreview for the stock bottom 2.0 crvtec making 204 horses. im scratching my head over this. that seems like a strong motor
Old May 2, 2003 | 07:09 AM
hybridmoose's Avatar
I have a JDM B20B block and a PR3 B16 head for my setup. Everything is "stock right now except Im running a Hondata. My setup is running 170whp as it is now,so im sure with some cams I could make about 200whp.
Old May 2, 2003 | 08:49 AM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoose &raquo;</TD></TR><TR><TD CLASS="quote">I have a JDM B20B block and a PR3 B16 head for my setup. Everything is "stock right now except Im running a Hondata. My setup is running 170whp as it is now,so im sure with some cams I could make about 200whp.</TD></TR></TABLE>
ur setup is just like mine, minus the hondata...either way, my car is faster than when it had just the b16 hehe
mike
Fourteenrbagger
16
Dec 29, 2015 11:31 AM
negusjuda
15
Jun 16, 2011 02:42 PM
alacard
Apr 26, 2007 12:11 PM
cvclover
Feb 21, 2007 03:28 PM
naSquad_ej8
13
Dec 8, 2005 03:13 PM
