what TEMP does a vavle cover reach>?
Old Apr 22, 2003 | 09:19 PM
Gusto222's Avatar
Default what TEMP does a vavle cover reach>?
if i use 600deg painT on my valve cover will it crack?
its for a 96 sohc non-vtec engine... doubt that matters...
what temp do valve covers reach?
Old Apr 23, 2003 | 06:46 AM
88_SC_CRX_Si's Avatar
New User
Default Re: what TEMP does a vavle cover reach>? (Gusto222)
That should work... I can't remember what temp the spray I used on mine was. However if the vavle cover reaches that high, then chances are the engine would be toasted. Since it's running around 180 degrees depending on what stat is being used... hehehe
Mikey3000's Avatar
the outside of the valve cover doesnt even get close to that hot. 600 degree paint will be good.
dr juice164
Aug 2, 2004 02:17 PM
mantic6t9
Mar 27, 2004 01:19 PM
Pineapple Devil
Dec 25, 2002 05:19 PM
vtec_powah
Sep 16, 2001 01:19 PM
