Carbon Fibers, Too small???
I was at a body shop today and I mentioned I wanted a CF hood, the guy laughed and said, they look good, thats it! I was like, "
", and then he said they don't fit, they are generally too small around the sides. Is this true H-T?
nope, not true. a lot of people have good experiences with CF hoods. there are some where the sides sit up higher than the car so that it leaves a gap, but i've never heard of a hood being too small.
It was Ture For Me, U can make it fit, it just depends on what brand you get, i have herd that VIS and Spoon and Fiber Imagies (spelling?) all fit great with the car. You get what you pay for.
I have a aerogear hood, if it wasn't for the hood pins the hood wouldn't of fit.
don't buy aerogear they suck.
I noticed that a lot of CF hoods allways have a gap on one side or the other, and never really sit even on a car, look the next one you see over good, and you will noticed it
my hood is kinda raised on the passenger side, but i think my latch is bent. otherwise the only problem isthat it doesnt go down far enough in the front
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_assassin »</TD></TR><TR><TD CLASS="quote">my hood is kinda raised on the passenger side, but i think my latch is bent. otherwise the only problem isthat it doesnt go down far enough in the front</TD></TR></TABLE>
There are some rubber stoppers up front that you can turn to adjust your hood's "height".
Also depends on the car. If a car has been hit before, the factory body panels may not line up correctly, and this may cause the cf hood to fit poorly
I just got a used Fiber Images hood....in all honesty...it fits better than i expected....it sits barely higher than the finders...not even noticiable...unless you specifically look for it....and the gaps between the hood and the fender are a tad wider than with the stock hood....maybe by...2-4 mm MAX....there is a small area on my driver side headlight that it sits a lil funny....but again...you dont notice it unless you're really looking for it....Fiber Images gets a huge
from me...also...hoodpins help a ton....and in my eyes are a must...
