Is there a fuel filter on a 4g lude??
Old Apr 22, 2003 | 05:53 PM
2000BoostedEX's Avatar
Default Is there a fuel filter on a 4g lude??
I know there has to be one somewhere but i went to go buy one cuz i was doing a tune up and well no one has one or can get one. Does there happen to not be one on my car????
Old Apr 22, 2003 | 06:00 PM
H23_92si's Avatar
It should definetely be one or things could go wrong with your engine.
Old Apr 22, 2003 | 06:04 PM
Greyout's Avatar
Default Re: (H23_92si)
there is a strainer on the pump in the tank, and a real one bolted to the firewall.
Old Apr 22, 2003 | 06:27 PM
anyone know why i cant find one at a store?? i have tried autozone and walmart.
Old Apr 22, 2003 | 09:19 PM
Greyout's Avatar
Default Re: (JL_LUDE)
walmart will not carry it, and the autozone employee was probably stupid
Old Apr 22, 2003 | 09:20 PM
Elkins911's Avatar
thats your problem... walmart and autozone. if you wanna upgrade, just go for a AEM universal fuel filter. if not, im sure kragen or pepboys will have it. if they dont have it... HONDA will have it.
if your not sure if your car has one (which it does). locate your fuel rail... its the rail connected to your fuel injectors. go to the left side of the fuel rail, there should be a hose running off of it. that hose should lead you to the nonexistant fuel filter.
good luck.
Old Apr 22, 2003 | 09:22 PM
ludin92's Avatar
Default Re:
they have them at autozone, i just replaced mine a few thousand miles ago. it's right on the fire wall and doesn't take but 20 minutes to do. make sure to dump out the excess fuel in the filter after you take it off.
Old Apr 23, 2003 | 03:40 AM
Behan's Avatar
Default Re: Is there a fuel filter on a 4g lude?? (JL_LUDE)
the fuel filter is on the back firewall, start at the fusebox and look to the the right its the first thing you'll see mounted on the fire wall. I bought mine at advance auto parts for like 15 bucks, i would recomend going to the dealer and getting one, i think they're like 25 bucks from honda
Old Apr 23, 2003 | 04:30 AM
93ludeSi's Avatar
I got a replacement filter at NAPA for a few bucks
Old Apr 23, 2003 | 05:55 AM
laughinxxx's Avatar
New User
Default Re: (93ludeSi)
The fuel filter is $20 from Honda and it takes 10 minutes tops. The only PITA was that I had a fuel gauge on top of mine, but it still didn't take long. Make sure to air out your garage afterwards though. I think I lost some brain cells from all of that fuel.
Old Apr 23, 2003 | 08:40 PM
Default Re: (laughinxxx)
ok well when i was at autozone, it showed up unavailable on the computer screen. I found it today when i looked for it. I am gonna go out tomorrow to try and find one. thanx alot
Mr.Highlife
Nov 7, 2009 06:23 AM
green eyed bandit
Aug 15, 2007 11:27 AM
I B BANGGIN
Jan 14, 2007 06:57 PM
elmalouno
Jul 8, 2004 10:48 PM
brody
Aug 15, 2002 12:52 AM
