car running hella rich, .75 volt o2 reading, and it bogs in low end a lot...
Old Apr 22, 2003 | 04:02 PM
89 CRX SI's Avatar
Default car running hella rich, .75 volt o2 reading, and it bogs in low end a lot...
Timing? I crank it one way on distributor and it gets a lot better but I cant go any firther... Maybe My belt is off a tooth? this is a b18 BTW...
I dont have access to a timing light till tommorow but I think it is the timing that would cause this anyone else?
Old Apr 22, 2003 | 04:21 PM
Jared's Avatar
Default Re: car running hella rich, .75 volt o2 reading, and it bogs in low end a lot... (89 CRX SI)
.75 is not very rich on a 0-1 v o2 sensor, your problem is somewhere else. if it get better by cranking the distributor all the way one way, i would suspect your timing is off. check the belt.
integra3586
Oct 15, 2005 01:56 AM
Supahatch
Jul 5, 2005 01:35 PM
92hybridAccord
Oct 11, 2004 07:23 AM
herde1724
May 15, 2004 02:11 PM
simpsond
Nov 30, 2003 04:41 PM
