CTR pisonts in LS B18A. Need Help!!
Old Apr 22, 2003 | 12:29 PM
jonyb's Avatar
Default CTR pisonts in LS B18A. Need Help!!
I'm trying to get CTR pistons in an LS block. The rods are too wide to be pressed on. What rods work with these pistons, or if I notch out the rod, what does the clearance need to be?
Old Apr 22, 2003 | 12:42 PM
AllMotorMadness's Avatar
Default Re: CTR pisonts in LS B18A. Need Help!! (jonyb)
In order to make ctr pistons fit on an ls rods you have to take it to a machine and have them take of 1mm from each side of the rods then it will work fine. I've done it many times already and it works!!!!!!!
Old Apr 22, 2003 | 01:07 PM
jonyb's Avatar
Default Re: CTR pisonts in LS B18A. Need Help!! (AllMotorMadness)
The rods have been resized already and are waiting for an answer about narrowing. One place told me 30 thousandths on each side of the rod. Thanks for your reply.
detroitdiscounts2000
Oct 13, 2006 10:00 AM
92DAIntegraXSI
Feb 4, 2006 09:51 AM
fox297
Aug 4, 2003 12:39 PM
Ivan
Apr 24, 2003 03:42 AM
Ivan
Apr 23, 2003 09:49 PM
