Size of the hub spindle nut?
The helms says 22mm all over the place, but I could have sworn it was larger than that. I was thinking 32mm for some reason...
Can anyone verify?
Can anyone verify?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BABY NSX »</TD></TR><TR><TD CLASS="quote">32mm is correct!</TD></TR></TABLE>
i had to take mine off over the weekend,
20 minutes
1 busted screwdriver
and with the help of 6ft long breaker bar i finally busted that biatch loose
20 minutes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floyd »</TD></TR><TR><TD CLASS="quote">So what's the deal? Just a typo all over the helms?</TD></TR></TABLE>
huh? where do ya see a typo, im curious now.
22mm is probably the size of the threaded part of the axle. 32mm is the size of the head of the nut.
I think every bolt size measurement in the service manual gives you the size of the bolt/nut, not the size of the head.
Lug nuts are 12x1.5 and you use a 19mm socket on the head of the nut.. same principal.
Justin
Justin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madslackin »</TD></TR><TR><TD CLASS="quote">22mm is probably the size of the threaded part of the axle. 32mm is the size of the head of the nut.
Justin</TD></TR></TABLE>
EXACTOMUNDO!
EXACTOMUNDO!
Hehe. You know, I was wondering about the lug nuts as well.
So what good is the helms if you can't check the diagrams, grab all of the correct sockets you will need, and line them all up within reach in descending order...
I need help.
I need help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floyd »</TD></TR><TR><TD CLASS="quote">So what good is the helms if you can't check the diagrams, grab all of the correct sockets you will need, and line them all up within reach in descending order...
I need help.
Thats easy:
10, 12, 14, 17
I need help.
</TD></TR></TABLE>Thats easy:
10, 12, 14, 17
Mooneyes13
Mar 2, 2006 10:07 PM
nEoMuGen
Apr 20, 2003 10:04 AM
