f22 oil pump on an f20b. possible?
Mr. Badwrench
ok here is the deal, i am having a swap dilema with this f20b in a 97 ex accord. the f22 has a crank angle sensor on the crank snout. the f20b doesnt i am assuming it is in the distributor. what are the possibilities of an f22 oil pump fitting an f20b? i may have to shim the pressure spring and i am not sure if volume will be a problem. any help? thanks in advance.
92civeg
Jan 15, 2006 09:12 AM
