help: how do i prime oil pump
Old Apr 21, 2003 | 09:42 PM
Cashflo's Avatar
Default help: how do i prime oil pump
pk, how exactly do you prime an oil pump. diagrams are a must since i am a visual learner.
Old Apr 21, 2003 | 10:09 PM
psi420's Avatar
Remove spark plugs, disconnect coil, unplug injectors.
Crank motor until oil pressure light goes out.
No pics, good luck!
Old Apr 21, 2003 | 11:30 PM
X2BOARD's Avatar
Default Re: (psi420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">Remove spark plugs, disconnect coil, unplug injectors.
No pics, good luck!</TD></TR></TABLE>
You could just pull the plug wires and injector plugs... If the oil pump is brand new and the motor had no oil (fresh build) do the above and:
Crank the motor over for 15-18 seconds at a time, at least 8 times.
This should supply enough oil to safely start the motor.
BTW, ensure you have a good charge on the battery, cold cranking causes the starter to pull large amounts of current, draining the battery quickly.
X2
Old Apr 22, 2003 | 12:43 AM
MikeSarr_GSR's Avatar
Default Re: (X2BOARD)
pull ignition coil fuse in cabin
pull fuel EMS fuse in engine bay
crank till the light goes out
replace fuses, turn over
Old Apr 22, 2003 | 08:43 AM
psi420's Avatar
If you dont remove the spark plugs, your motor will make compression, and that equals resistance.
If you remove he spark plugs, it goes alot faster and is easier on your motor.
Old Apr 23, 2003 | 09:47 AM
good point
Old Apr 23, 2003 | 01:35 PM
Cashflo's Avatar
Default Re: (MikeSarr_GSR)
thanks all. i gueass my new oil pump is primed, but my oil light still wont go away. what else can i check. i also installed an oil pressure guage and it doesnt read anything. the oil level is also fine aswell as the oil pick-up. i hear clicking also, but it sounds like i need a valve adjustment. could this also be the sound of a rod knocking?
Old Apr 23, 2003 | 02:38 PM
BoostingSnail's Avatar
Default Re: (eghead)
no oil pressure=
if you hear the noise coming from the valve cover area..it's coming from the valve train...if the source of the noise is coming from the bottom end..it could be a bearing. a good way to make sure your oil pump will prime before starting an engine is to pack the oil pump gears with vaseline.
The more info you give us the more we can help you out
jrp355
Sep 30, 2011 04:46 PM
beana
Sep 27, 2008 10:31 PM
Expletive!
Dec 22, 2005 07:02 PM
PyroVTEC
Aug 19, 2002 08:12 AM
