Quaife Problem: Installation/Fitment
Old Apr 21, 2003 | 05:53 PM
slofu's Avatar
Default Quaife Problem: Installation/Fitment
i pressed the ball-bearings fully onto the diff (as says the Helm), but when i put the diff into the case (98-01 JDM ITR) now, it sits so low that the ring gear hits the case. the diff is in completely and straight (as are the bearings). am i missing a shim? the ring gear is on properly, all bolts are torqued to spec. i am using the Helm, but it calls for no shim on the clutch housing side, in which the diff is installed. any ideas?
Old Apr 21, 2003 | 07:21 PM
speed's Avatar
Default Re: Quaife Problem: Installation/Fitment (slofu)
If it is all put together correctly and the ring gear is rubbing the casing then you will need shims/spacers.
Old Apr 21, 2003 | 07:42 PM
slofu's Avatar
Default Re: Quaife Problem: Installation/Fitment (speed)
ok, but is this normal for a Quaife in my application?
NoXqcsMotosport
Transmission & Drivetrain
May 22, 2013 02:22 PM
migueldiaz
Honda Civic (2006 - 2015)
Jul 30, 2011 04:41 PM
Boostin Ex
Dec 22, 2006 04:02 PM
ocjdmek
Jan 7, 2005 02:41 PM
slofu
Apr 24, 2003 03:54 PM
