wheel offset
can somebody explain the difference between 42mm and 50mm offset
and how does it compare to the stock 45mm offset?
Offset is how far in or out the wheels stick. It's the lateral difference between (a) the mounting surface (the flat surface of the hub and of the inside of the wheel) and (b) the center of the wheel. Most FWD cars have more of the wheels surrounding the hub, which is called "positive offset" - the bigger the number, the more they're offset inwards toward the center of the car. Some cars (like "low riders") have negative offset - in which case the bigger the number, the more they stick out.
The 50mm offset is probably there for the 5G Prelude guys. Not sure what size you are thinking about, as that will affect offset requirement as well as the width.
If you want to run 225s without rubbing get the 50mm offset.
the 43 mil offset will allow more space for bigger brake calipers, but you will be limited to a 215 section width tire unless you roll your fenders.
