what is offset??
Old Jul 12, 2005 | 06:16 PM
torqueless's Avatar
Default what is offset??
what does offset mean? example: 15" rims 4x100 40mm offset???
Old Jul 12, 2005 | 07:35 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what is offset?? (torqueless)
Whenever you have a question about wheels or tires, you can probably find the answer on the Tire Rack website.
Their web page on offset says:
Offset
[i]The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
Old Jul 13, 2005 | 12:12 PM
Mike_C's Avatar
Default Re: what is offset?? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Whenever you have a question about wheels or tires, you can probably find the answer on the [url=http://www.tirerack.com]Tire Rack Website</TD></TR></TABLE>
Or in the Forum FAQ!
Drew17th
14
Sep 24, 2008 04:56 PM
Ponyboy
Apr 15, 2007 12:39 PM
HamiltonRex
Oct 12, 2005 11:56 AM
Cheap Bastard
Jan 29, 2003 12:36 PM
Norcalstoppy
Nov 22, 2002 04:00 PM
