problem after gsr swap, help needed desperately!!!!!
Old Apr 21, 2003 | 03:04 PM
743power's Avatar
Default problem after gsr swap, help needed desperately!!!!!
I just swapped an obd2 gsr motor into a 94 ls. I ran vtec solenoid, oil pressure switch and knock sensor. I'm running a skunk 2 chipped p28. There is no check engine light, but the problem is that the car will not rev past 4000rpm. I need to figure this out tonight. Does anybody know what could be wrong?
Old Apr 21, 2003 | 03:23 PM
poison's Avatar
Default Re: problem after gsr swap, help needed desperately!!!!! (743)
Are you getting a CEL?
Old Apr 21, 2003 | 03:26 PM
Shift!'s Avatar
Default Re: problem after gsr swap, help needed desperately!!!!! (poison)
Try to borrow a OBD II Ecu from a GSR and swap that in.... It *could* be your ecu
Old Apr 21, 2003 | 03:27 PM
poison's Avatar
Default Re: problem after gsr swap, help needed desperately!!!!! (Shift!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shift! &raquo;</TD></TR><TR><TD CLASS="quote">Try to borrow a OBD II Ecu from a GSR and swap that in.... It *could* be your ecu</TD></TR></TABLE>
could be, very possible. he has a 94 ls as well being OBD1.
Try using your stock P75 ECU.
untitled's Avatar
what do you mean it wont rev. does it hit fuel cut
Old Apr 21, 2003 | 03:45 PM
743power's Avatar
Default Re: problem after gsr swap, help needed desperately!!!!! (88crx91integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean it wont rev. does it hit fuel cut</TD></TR></TABLE>
Doesnt feel like the rev limiter. It gets soft around 3200-3500 and kinda just slows down to a putter, like it can't get past 4000 rpms. I havent driven it, just messing with it in the driveway. No CEL's, will try the LS ecu in an hour.
Old Apr 21, 2003 | 04:23 PM
743power's Avatar
anyone?
Old Apr 21, 2003 | 05:13 PM
743power's Avatar
ok, it was the ecu. I'm gonna have to talk to the guy I got it from and see what we can do. Thanks for the help.
Old Apr 22, 2003 | 04:48 AM
Shift!'s Avatar
Awesome! At least youve narrowed down your problem
Old Apr 22, 2003 | 11:17 AM
743power's Avatar
gsr motor on ls ecu runs rich. Still trying to figure out the problem with the p28 though.
jlfrnce
May 1, 2007 06:05 PM
nek9
Dec 9, 2006 06:54 PM
god.loves.ugly
Apr 21, 2006 11:04 PM
hatchyboy89
Apr 15, 2005 09:53 AM
743power
Apr 22, 2003 06:33 PM
