my quest for 200 all OEM horse power
Guest
Posts: n/a
My goal: 200hp using all OEM equipment
(note) I will be using some aftermarket companies to reach my goal
the motor: 98 spec B18C5
-portflow head
-00 ITR intake shaft
-CTR oversized pistons
the motor work: -full engine blueprinted and balanced
-port+polished head (portflow)
-port matched intake manifold
-bored .25 over
-bored over throttle body
transmission: -JDM 98+ transmission
-ATS limited slip differential
-toda full face clutch/flywheel
Aftermarket parts: -hondata program (not sure which one would best suit me)
-toda cam gears
-mugen CAI
-toda head gasket?/mugen
-hondata I/M gasket
Exhaust: -jdm ITR header (jet coated) with heat sheild
-all bottle necks removed in exhaust
this motor will be built for auto-x/roadracing/drag
/and street drivability.
I'll keep you guys updated.
any 00 or 01 Rs that upgraded their cams wanna sell me your stock set?
power steering and air conditioning are removed.
Modified by DC-2R at 12:05 AM 4/22/2003
-portflow head
-bored .25 over
-toda cam gears
-mugen CAI
-hondata I/M gasket
/and street drivability.I'll keep you guys updated.
Already done:
https://honda-tech.com/zerothread?id=344002
You might have to get Chris to reload his plot for you though.
Austin
Austin
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin »</TD></TR><TR><TD CLASS="quote">Already done:
Austin</TD></TR></TABLE>
I'm pretty sure ep did it also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan »</TD></TR><TR><TD CLASS="quote">I'm confused??? "All OEM horse power"
but then you say you'll use aftermarket equipment???
pick one & stick to it
I need to increase horsepower by using aftermarket parts and other modification of course but yet still maintain OEM type reliability.
</TD></TR></TABLE>I need to increase horsepower by using aftermarket parts and other modification of course but yet still maintain OEM type reliability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2R »</TD></TR><TR><TD CLASS="quote">do you think that my setup is capable of yeilding me 200+hp?
what hondata program do you think would best apply to me? (sgt)
Ummm....have you looked into the Hondata system and taken a look at what you need, it's pretty easy to realize that you just need an S200 and can upgrade it as you wish at a later date.
Austin
Austin
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Rare#1248 »</TD></TR><TR><TD CLASS="quote">forget the jdm header and get something better...it doesn't affect the car's reliability</TD></TR></TABLE>
I've looked at a few of the "GOOD" header companies such as header-tech, smsp, and hytech but they didn't have anything that woould give me their crazy hp gains while still being able to fit under a oem heat sheild. that is something I will be looking into for my race motor.
Guest
Posts: n/a
the s200 is what i've been looking at just didn't know if there was something that I wasn't aware of.
b16supertuner
Jan 23, 2007 05:39 PM
b16supertuner
60
Jan 10, 2006 12:41 PM
