clutch problems
Old Apr 21, 2003 | 09:59 AM
girlyEG's Avatar
Default clutch problems
just finished installing a stage 3 CM clutch and a CM flywheel in a type r. we bleed the slave cylinder after and everything that is suppose to be done now the fork has a lot of movement but the pedal isn't that hard to push maybe not even as stiff as stock. What could my problem be???? also the tranny won't go into some gears.
Old Apr 21, 2003 | 03:08 PM
Teepo's Avatar
Default Re: clutch problems (girlyEG)
When we install clutches we buy everything new. pilot bearing, throw out bearing, seals , slave and master. It offers the customer more assurance that future clutch problems will not be likely in the near future. A new master and slave wont run you that much. When you install them, bleed correctly, make sure you bleed the master and that it never runs out of fluid while bleeding. You should be good to go. Or defective pressure plate and/or throw out bearing
Topdawgg
Mar 26, 2013 08:04 PM
tigersball
Jul 9, 2008 09:45 PM
polishedturd
Feb 8, 2008 03:32 AM
JdMhEaD
Nov 6, 2006 12:47 PM
kordenbrock motorsports
Sep 29, 2005 07:44 PM
