Is there a way to wire Vtec to a shift light?
Old Apr 21, 2003 | 01:18 PM
Hondasaurs's Avatar
Default Is there a way to wire Vtec to a shift light?
I am having a lot of problems with getting my Vtec to engauge. I'm starting to think I may have a problem with my ECU (P61). I've tested the solenoid and it works, it clicks and the engine bogs down when I put 12V to it. My VSS is most likey screwed up in my wiring conversion. How do I wire the Vtec to the shift light on my tach?
Old Apr 21, 2003 | 01:39 PM
poison's Avatar
Default Re: Is there a way to wire Vtec to a shift light? (ZC_CRX)
You just need to tap into the VTEC solenoid wire (or splice into the A4 pin-out), take a light and mount it where ever you like, then ground the light and you're done.
Old Apr 21, 2003 | 01:43 PM
Hondasaurs's Avatar
Default Re: Is there a way to wire Vtec to a shift light? (poison)
I have the shift light on my Autometer tach. Is there a way I can just tap the positive on the shift light?
Old Apr 21, 2003 | 01:54 PM
dfoxengr's Avatar
yeah its possible to do that too..basically, when power goes to the solenoid, your light gets power too, its just switched power.
Old Apr 21, 2003 | 01:57 PM
Hondasaurs's Avatar
Default Re: Is there a way to wire Vtec to a shift light? (hybridvteceg)
I just wanted to make sure before I go and burn something out. Thanks!
crooked muffler
29
Oct 17, 2018 04:54 PM
97grnrs
Nov 29, 2006 05:08 AM
ham
Jul 8, 2004 05:58 AM
s2kkk
May 10, 2004 09:33 AM
