oil leak help
Old Apr 21, 2003 | 11:52 AM
shming123's Avatar
Default oil leak help
on my rebuilt gsr motor, so far i've got about 300 miles on it and everytime i look at the engine after i drive it, there is a small oil leak at the head gasket right above where the "B18C" is written.i don't notice any oil loss on the dipstick, but i am concerned..why is it leaking? what needs to be done? at about 800 miles i was gonna take it for a tune up, can i wait till then? or is this one of those things that needs to be done RIGHT NOW? thanks for all of the help.
Old Apr 21, 2003 | 12:19 PM
psi420's Avatar
Sounds like your Cylinder Head Plug is leaking. (Most call it a Cam Seal)
Those are prone to leaks.
If not that, then it could be your distributor O-Ring.
Both are very simple fixes.
Old Apr 21, 2003 | 12:54 PM
shming123's Avatar
no, the exact spot its leaking from is where u can see a little bit of the head gasket..(its metal right?) and its coming from there....is it ok to leave it like that for a while?
Old Apr 21, 2003 | 01:25 PM
psi420's Avatar
Default Re: (shming123)
If you notice very little drop in your oil level, sounds fine. Just keep an eye on it and make sure it doesnt get much worse.
Old Apr 21, 2003 | 01:40 PM
shming123's Avatar
thanks. :-)
swizz977
49
Nov 20, 2011 03:09 PM
djb97ek
Apr 11, 2010 09:00 PM
cltitus
Mar 3, 2007 01:55 PM
98GreenTegGSR
Dec 18, 2006 11:56 PM
Alpha_GSR
May 9, 2002 07:27 PM
