How to remove Crank Pulley with motor sitting on garage floor?
Ok, I have my H22A1 sitting on a cart on the floor of the garage, how am I going to remove the crank pulley bolt? How am I going to keep the motor from turning over? Help? Suggestions?
use a crank pulley wrench to hold it stationary and an impact wrench to break the bolt.
Moroso makes a crank pulley wrench for all Hondas.
Well, I had the same dilemma. What i did was wrap the pulley with some ratcheting tie'downs and lock the pulley in place with that.. Just tie it down to the workbench or something. Then, just whack the wrench with an impact. That did it for me!
wouldn't you also be able to use Honda's flywheel removal tool? The thing that holds the flywheel in place to remove/install it?
djnikko
19
Apr 24, 2005 07:43 PM
