ek motor mount ?
Old Apr 21, 2003 | 07:12 AM
black-hatch's Avatar
Default ek motor mount ?
im doing a b18 swap into my ek hatch im confused on the driver side mount do i just use the civic si bracket or do i need the whole mount
Old Apr 21, 2003 | 08:28 AM
IS3Fifty's Avatar
Default Re: ek motor mount ? (black-hatch)
you need to use b18 mounts except for rear tranny mount.. that needs to be 99-00 si.
Old Apr 21, 2003 | 09:08 AM
Trey's Avatar
25 Year Member
Default Re: ek motor mount ? (purek9hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purek9hybrid &raquo;</TD></TR><TR><TD CLASS="quote">you need to use b18 mounts except for rear tranny mount.. that needs to be 99-00 si.</TD></TR></TABLE>
Ummm...no,
Upper driver side, you use the EK liquid filled mount and bracket. On the block, you use the 99-00 Si bracket (bolts below the cam gears). B18 block bracket is three pronged, 99-00 Si is two pronged.
yayizzil
Apr 3, 2009 01:05 PM
blackeg
May 2, 2005 07:50 AM
CallmeLuke
Nov 28, 2003 10:12 PM
turbospool
Sep 29, 2003 10:12 PM
deviant1
Mar 21, 2003 11:03 PM
