Wheel size and loss of power
Old Apr 21, 2003 | 03:49 AM
lMlElNaCe-GsR's Avatar
Default Wheel size and loss of power
I have heard that even though you may have light rims the larger diameter of the rims will slow down your car even if its the same weight of a smaller diameter rim. But after i bought some forged 17" Volk TE37's it actually felt faster then when i had my 15" GSR rims which were about 1 or 2 pounds heavier. So is it true that if you have a lighter rim then a smaller diameter rim the larger diameter rim will effect power more?
Old Apr 21, 2003 | 05:01 AM
prophet's Avatar
Default Re: Wheel size and loss of power (lMlElNaCe-GsR)
the overall diameter of the wheel (wheel + tires) will be around the same because with larger rims you tend to buy smaller profile tires. Then you got to add in the fact with lower profiled tires it may actually weigh less than the larger profile, smaller diameter tires. Weigh both the tires and rims and you will see that they are probally almost the same as the gsr ones. I noticed my 13 inch steelies + tires weigh close to the same as my rota 15's with tires...
Old Apr 21, 2003 | 06:40 AM
pills_PMD's Avatar
http://www.hondaswap.com/articles/viewer.php?id=41
http://www.hondaswap.com/articles/viewer.php?id=40
Old Apr 21, 2003 | 06:58 AM
Lsos's Avatar
Both a larger rim and a heavier rim will slow acceleration.
A combination of how much weight there is how far from the center of the rim will affect acceleration. This is moment of inertia. Ideally, you want a light rim with most of its weight concentrated around the center.
Old Apr 23, 2003 | 12:00 AM
Default Re: (pills_PMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pills_PMD &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondaswap.com/articles/viewer.php?id=41
http://www.hondaswap.com/articles/viewer.php?id=40</TD></TR></TABLE>
"You must be a logged-in member to view this page."
iCollectStraws
May 21, 2009 05:06 AM
jond
16
Mar 8, 2005 09:12 AM
94gsr18kid
Jan 2, 2005 10:53 AM
blacks2000
Honda S2000
Nov 25, 2002 05:44 PM
h22accordturbo
Nov 5, 2002 02:27 PM
