need help changing axle
i have a 95 civic with a b18c and my passenger axle boot is leaking.i have to change the axle because i feel like doing it instead of messing with cv boots and ****. but anyway: how hard is it? i know i have to drain the tranny fluid and i am not worried about that because i wanted to change my tranny fluid anyway. but what else do i have ot know? i have already done a drivers' side one in my car and in my friends car this past weekend and it is pretty easy especially after i used my car as the learning experience but we did it in about 30 minutes. the hardest thing is just getting the side bolted the the intermediate shaft off but after that it is cake. but i have heard that changing the passenger side axle is different and much more difficult. what advice can you guys give me? what special things do i have to know to change the other axle? let me know
you need a 32mm socket and a long *** breaker bar...take off the axel nut, then take off a castle nut right by were the rotor is located ....take the axel out from the rotor and then pry out the axel from the tranny....fairly easy...or get a service manual and learn....
good luck
good luck
yeah i know about the socket and the breaker bar because i already have those tools because i have done my drivers side axle. but i was wondering if i had to know anythign special to do the passenger side axle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjdmgsr »</TD></TR><TR><TD CLASS="quote">i didn't change the intermediate shaft, i just changed the driver's side axle</TD></TR></TABLE>
So? Its the same ****. Nothing different at all.
when i did the driver's side axle i just tapped it off where it was bolted on the the intermediate shaft. on the passenger side, am i supposed to do the same thing to get it off? just tap it off? so there is nothing different about the sides since i didn't change the intermediate shaft when i did the drivers side? so you saying that the passenger side is exactly the same? thanks for your help guys
because some one told me about some clip i have to replace or something like that but i wasn't sure what they were talking about since there was no clip on the drivers' side. all i did was remove everything out of the way to get it off and then i just tapped the drivers side axle off and then i just put slid the new axle in and put everything back together. so am i missing something?
It sounds like it`s stuck, I`ve had the same issues before, just beat it w/ a dead blow hammer(made from rubber) or a mallet(not a mullet, LoL) and It`ll break free...Beat it, just beat it
it's not bad to just replace one axle right? cause the boot on my passenger side is ripped up and clicking when i turn.. pep boys i heard has a good price on axels right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass »</TD></TR><TR><TD CLASS="quote">wedgre the claw part of a hammer in where its going into the tranny and move it like you were trying to pull nails out. do it hard and itll pop loose</TD></TR></TABLE>
so it is exactly the same as the driver's side then right? if it is then i'll be able to do it in like 30 mins
so it is exactly the same as the driver's side then right? if it is then i'll be able to do it in like 30 mins</TD></TR></TABLE>
basically...pretty simple stuff. Just make sure you don't rip the transmission seal when you pry out the old axle. If you have a pickle fork, use it to pry the axle out of the transmission. It works very well.
Here's a like to Tom's thread...Pics and all.
Click here: https://honda-tech.com/zerothread?id=382416
best of luck
best of luck
