Planning out motor build....Do I need retainers/springs?
I'm lookin to build my B18B to handle about 300whp. The plan so far is to build the block with JE SRP pistons/Eagle rods, but no stock sleeves. I got the recommendation from Howard at AR Fab to also upgrade my valvetrain with retainers/springs and SS valves. Reason being: "....the valve train upgrade is necessary due to the boost wanting to open the valves easier...valve float with 18psi will start at 4000rpm...." ....is this true?
With these components and hondata running me around 15psi (t3/t04, 54 trim) I'm hoping for 300whp reliably . Am I accounting for everything I need to do this? Is sleeving not gonna be important for this power level? Also, what size injectors should I run?
Modified by Teg4e at 1:24 AM 4/22/2003
I would consider a motor rebuild on any LS to start from the head down. Thats how power on that motor is made. So yes, dont skimp on the valvetrain.
I gave you all the help you need....what, is this not enough.
Damn, someone reply with a "what he said" to make him happy
No, it's not enough, b/c there's a bunch of other unanswered questions in there. i.e. sleeving, injectors.
so, even with a well-tuned hondata, you still think sleeving is a good idea for 300whp?
Modified by Teg4e at 1:09 PM 4/22/2003
hey ethan, put a **** in your mouth...
haha jk....leave the head alone for now.....and sleeve that sucka...do it once do it right...and when u get 300whp, u'll want more
shamoo
Jan 31, 2002 07:03 PM
