10.2:1 to 9.2:1 compression....... how much power lost?
Old Apr 20, 2003 | 09:26 PM
airborne84000's Avatar
Default 10.2:1 to 9.2:1 compression....... how much power lost?
If I dropped my pistons to 9.3:1 / how much horses would be lost in the process?
Thanx
Old Apr 20, 2003 | 09:29 PM
MaxBoost's Avatar
New User
Default Re: 10.2:1 to 9.2:1 compression....... how much power lost? (airborne84000)
More details on the setup. Most likely on a turbo setup you would gain horsepower. You could run more timing and more boost.
Old Apr 20, 2003 | 09:48 PM
Default Re: 10.2:1 to 9.2:1 compression....... how much power lost? (MaxBoost)
ohh sorry
Je 10.2 pistons, vavletrain, head ported, crank balanced and jrsc pushing 6psi
thanks
Old Apr 20, 2003 | 10:24 PM
T-sohctec's Avatar
not enough to make a diff. & if you do feel a diff. then just up the boost
Old Apr 20, 2003 | 10:27 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">More details on the setup. Most likely on a turbo setup you would gain horsepower. You could run more timing and more boost.</TD></TR></TABLE>
yeah, but if you have same timing and boost, just higher cr, the higher cr will yeild more power...
Old Apr 20, 2003 | 10:28 PM
93LSivic's Avatar
You would lose exactly 7.342 whp for every psi of boost in a mountainous region. Only about 5.893 whp if your at sea level.
Old Apr 21, 2003 | 12:40 AM
blufke's Avatar
Default Re: 10.2:1 to 9.2:1 compression....... how much power lost? (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">You would lose exactly 7.342 whp for every psi of boost in a mountainous region. Only about 5.893 whp if your at sea level.</TD></TR></TABLE>
*ahem*, get your facts straight man! dont misinform him. its 7.343 whp and 5.892 whp. GEEZ. bastards.
Old Apr 21, 2003 | 01:36 AM
Cyber ITR's Avatar
Default Re: 10.2:1 to 9.2:1 compression....... how much power lost? (blufke)
where do you get that figure from if u dont mind me asking
Old Apr 21, 2003 | 05:16 AM
GreddySi99's Avatar
Default Re: 10.2:1 to 9.2:1 compression....... how much power lost? (SEX DR)
If you are building the engine for a JRSC DO NOT USE LOW COMPRESSION PISTONS. you will only hurt you WHP numbers. People who make the big numbers with a JRSC use between 10:1- 11:1 pistons. the reason for this is the blowers low boost and high heat output. Now if you are going to use compound induction then it will be ok but you will still lose HP
Old Apr 21, 2003 | 06:23 AM
Tinker219's Avatar
Default Re: 10.2:1 to 9.2:1 compression....... how much power lost? (intercooledJRSC)
A higher compression motor will make more HP on the same amount of boost than a lower compression motor. Do a search, there is a HUGE thread on this that firmly establishes this theory.
Old Apr 21, 2003 | 07:38 AM
PrecisionH23a's Avatar
Default Re: 10.2:1 to 9.2:1 compression....... how much power lost? (Tinker219)
correct me if im wrong, but when n/a for every CR point it is a ball park average of 10hp you increase... im not sure how accurate this is for turbo applications though.
Old Apr 21, 2003 | 03:46 PM
well on of the reasons that I wish to lower the compression is for the longtevity. i was told my a mechanic that head gaskets will blow with high *** compression like 11:1 or 12:1 w/ a blower. He does a lot of work on big block V8 motors though, are they naturally a LOT less compression than 4 bangers???
thanks
Old Apr 21, 2003 | 03:58 PM
CRVRX's Avatar
I have found from past experiance , 1 point is about 10 WHP . This is a rough number from what I have seen in the past.
ie, 10-1 down to 9-1.
Modified by CRVRX at 3:41 AM 4/22/2003
Old Apr 30, 2003 | 07:07 AM
xonn's Avatar
4-6% at the wheels
Freshdot
Nov 15, 2012 07:10 AM
meric0786
Oct 4, 2005 05:55 PM
deemack79
Feb 14, 2005 05:33 PM
hahaitzsteven
Jan 9, 2005 06:09 PM
SJP0tato
Nov 6, 2003 11:19 PM
