pushrod engines
Old Apr 20, 2003 | 07:30 PM
comptechgsr's Avatar
Default pushrod engines
what makes them differ from the basic sohc/dohc engines
Old Apr 20, 2003 | 08:11 PM
IN VTEC's Avatar
Default Re: pushrod engines (comptechgsr)
Method of valve actuation.
Old Apr 20, 2003 | 08:13 PM
TREVER's Avatar
the cam is in the block and moves the rocker via the pushrod
Old Apr 20, 2003 | 08:16 PM
Default Re: pushrod engines (TREVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">the cam is in the block and moves the rocker via the pushrod</TD></TR></TABLE>
so the lobes of the cam, say push the 'rods' that open/close the valves..
as opposed to the 'normal' way, where the lobes str8up open/close the valves?
Old Apr 20, 2003 | 09:11 PM
IN VTEC's Avatar
You're leaving out the rocker arms.
OHV engine: Cam - pushrod - rocker arm - valve
OHC engine: Cam - rocker arm - valve
And, who said that overhead cams are the normal/original way of doing it?
Old Apr 20, 2003 | 09:16 PM
Default Re: pushrod engines (IN VTEC)
i said normal,
in the hondizzle sense
Old Apr 21, 2003 | 12:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
the pushrods are why OHV engines can't rev very high. Those long rods don't take to high RPM very well.
Old Apr 21, 2003 | 05:32 PM
Wes V's Avatar
Default Re: pushrod engines (PatrickGSR94)
It's not the length of the push rods that limit the RPM, It's due to the combined weight of all items involved working the valves.
Wes Vann
Old Apr 21, 2003 | 07:27 PM
Lsos's Avatar
I like the Yamaha heads (Taurus SHO, Celica....?)
No rockers, just cam - valve. It seems so much simpler...
Old Apr 22, 2003 | 05:56 AM
JimBlake's Avatar
Default Re: pushrod engines (Lsos)
So what are they, shim & bucket lifters? My old '82 Rabbit & my dad's old '71 Fiat 128 had those. Adjusting valves is a pain, but they almost never went out of adjustment.
Old Apr 22, 2003 | 08:50 AM
psi420's Avatar
Pushrods suck ***!
Old Apr 22, 2003 | 10:12 AM
Lord Helmet's Avatar
also the design of the pushrod location limits the design of the intake manifold. why do you think ford switched to DOHC for their mustang.
Old Apr 22, 2003 | 11:53 AM
Default Re: pushrod engines (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">also the design of the pushrod location limits the design of the intake manifold. why do you think ford switched to DOHC for their mustang.</TD></TR></TABLE>
they switched?!?!?
when?!??
w/ the 2003 stang in my avatar?
Old Apr 22, 2003 | 12:11 PM
NSX Bob's Avatar
New User
I'm not sure of this (I'll make that disclaimer before I get jumped on), but I think they went from OHV to OHC when they dropped the 5.0 and put in the 4.6. That was in 1997 or 1998, <U>I think</U> .
Old Apr 22, 2003 | 12:50 PM
psi420's Avatar
95 was the last OHV 5.0
urgonnalearn2
Nov 2, 2004 04:51 PM
borndahoop
May 13, 2004 03:13 PM
GIZZ - EXV
Apr 25, 2004 08:43 PM
91integraLSVTEC
Aug 22, 2003 08:54 PM
RacerZook
Aug 2, 2003 08:55 AM
