Quick Q: about valve adjustment
Old Apr 20, 2003 | 03:38 PM
P1mpSlap's Avatar
Default Quick Q: about valve adjustment
When I'm adjusting on cylinder #1 at TDC on the intake side. Can I immediatly switch below to the exhaust side to adjust those?
Or do I have to finish the intake side then move to the exhaust side?
Old Apr 20, 2003 | 03:41 PM
.RJ's Avatar
.RJ
Default Re: Quick Q: about valve adjustment (P1mpSlap)
I really dont understand your question.......
but you adjust both intake and exhaust valves at the same time (when that cylinder is at TDC, both sets of valves are closed).
Old Apr 20, 2003 | 03:42 PM
P1mpSlap's Avatar
You answered it.
I just didn't want to have to adjust the intake side once, then finish, and move to the exhaust side and repeat the process.
Old Apr 20, 2003 | 03:46 PM
.RJ's Avatar
.RJ
Default Re: (P1mpSlap)
refer to your helms manual
you really should have one if you're doing this type of maintenance yourself.
Old Apr 21, 2003 | 12:36 AM
BIGGIDYBOB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
well some people recommend doing it this way so you wont make the mistake of mixing up feeler gauges..if u kno wut i mean. i think thats just more work. do both intake and exhaust at the same time
jerzey908
May 13, 2009 01:34 PM
doublejz
Oct 24, 2005 02:10 PM
x00gsr
Jul 31, 2004 02:56 PM
raene
Jun 25, 2001 10:29 AM
