Constant Hitting From Sub
Guest
Posts: n/a
Hey i recently installed my sub on my car witha 1200 watt amp powering it. I think it is able to handle the power becuase it was working... then i disconnected it so i could hide the wires, i blew a fuse some how. I replaced it but i still am getting this constant hit from my sub like even when it is in between songs. Any ideas on what it might be. I would like to fix it myself because i dont feel like paying the guys and car toys to do it. Thanks
Well... its one of two things... First try turning down the power leads and adjusting them on your amp... If that doesnt change anything which is likely... You need to hook your RCA jacks up to a different output jack. Most likely you blew it up and its totalled... Mine is hooked up to my rear outputs cause I blew the sub ones.... I bet you can fix by just adjusting the power on your amp...
